查看: 15993|回复: 2
关于programde 的问题
发表于 2003-8-1 14:56:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
c : this macro takes a standardized note, lets the user input specific variable
c : values, and then puts this note on the drawing where the user specifies.
c :
c : In this example the user is specifying minimum letter height to be on a part,
c : maximum inside radii, and maximum outside radii.
c :
c : This assumes all note settings are as desired and you want to create a
c : note in your current workview.
c :
c : The array line will contain the lines of the note.
c : The array templine will contain the second half of lines where a variable
c :     is to be inserted.
c :
# string lin(15)
# string templn(3)
c :
# lin(1)  = "NOTES:"
# lin(2)  = " "
# lin(3)  = "    1. DOD-STD-100, ASTM E380 AND ANSI Y14.5M-82 APPLY"
# lin(4)  = " "
# lin(5)  = "    2. MARK PART NO. AND REV. LEVEL BY INK STAMP IN"
# lin(6)  = "       APPROXIMATE AREA SHOWN USING "
c :
# templn(1)  = " MIN. HIGH LETTERS"
c :
# lin(7)  = " "
# lin(8)  = "    3. DIMENSIONS IN ( ) ARE IN U.S. CUSTOMARY UNITS"
# lin(9)  = " "
# lin(10) = "    4. ALL DIMENSIONS APPLY AFTER SURFACE TREATMENT"
# lin(11) = " "
# lin(12) = "    5. UNLESS OTHERWISE SPECIFIED:"
# lin(13) = "        a) ALL INSIDE RADII TO BE "
c :
# templn(2) = " MAX"
c :
# lin(14) = "        b) ALL OUTSIDE RADII TO BE "
c :
# templn(3) = " MAX"
c :
# lin(15) = "        c) NO BURRS OR SHARP CORNERS PERMITTED"
c :
c :
c : Interactively prompt the user for the minimum letter height to be on a part.
c : Repeat this until a value is entered.
c : A value has been entered if the status is not equal to negative one.
c : Interactively prompt the user for max inside radii,repeat until entered.
c : Interactively prompt the user for max outside radii,repeat until entered.
c :
# status = 0
# repeat
#     erase prompt
#     show  prompt ("What is the minimum height of letters?")
#     get number (minheight,status)
# until (status NE -1)
c :
# status = 0
# repeat
#     erase prompt
#     show  prompt ("What is the maximum inside radii value?")
#     get number (maxinrad,status)
c :
# status = 0
# repeat
#     erase prompt
#     show  prompt ("What is the maximum outside radii value?")
#     get number (maxoutrad,status)
c :
c : Form the lines the need variable input.
c :
# minheightstr=valtostr("%.2f",minheight)
# maxinradstr=valtostr("%.2f",maxinrad)
# maxoutradstr=valtostr("%.2f",maxoutrad)
c :
# lin(6)  = lin(6)  + minheightstr + templn(1)
# lin(13) = lin(13) + maxinradstr  + templn(2)
# lin(14) = lin(14) + maxoutradstr + templn(3)
c :
c : Interactively prompt the user to enter a digitize point
c :
# status=3
# repeat
#     erase prompt
#     show  prompt ("Digitize where you would like the note to appear:")
#     get digitize (xdig,ydig,status)
# until (status EQ 0)
# inquire view number (viewcurrent)
# digpoint = "L:   " + viewcurrent + "  " + xdig + "  " + ydig
c :
# read system variable ("note_downspace",notedownspace)
# read system variable ("note_height",noteheight)
c:
# spacing=0
# for i=1 to 15 do
#   create text(xdig,ydig - (i*spacing),lin(i))
#   spacing=notedownspace * noteheight
# next
E : END
在i-deas中的错误:
Error, line 96: invalid procedure call; check syntax and arguments.
就是create text()那一行!!!!!!!!
哪位大侠帮俺们一下啊!
发表于 2003-8-1 15:45:44 | 只看该作者
二次开发的高手来帮帮忙啊,这几天都快被折腾停了。。。
发表于 2003-8-6 17:50:20 | 只看该作者
提示语法错误,应该很容易解决吧
GMT+8, 2025-2-10 08:15 , Processed in 0.027171 second(s), 13 queries , Gzip On, Redis On.
