查看: 20992|回复: 3
好消息---proe wf5.0可以免费升级至creo parametric 1.0
发表于 2011-6-8 10:20:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://creo.ptc.com/2011/06/07/creo-reactions-the-unanswered-questions-answered/
1. What will be the upgrade paths from the Creo Elements (a.k.a. Wildfire 5 M080) packages to Creo application suites?
Every Creo Elements product, package, and extension has an upgrade path to Creo, for example, a customer with Creo Elements/Pro on maintenance has the option to upgrade to Creo Parametric, a customer with the Creo Elements/Pro Foundation will have an upgrade path to a package of the corresponding Creo Parametric capabilities, and so on.  At a minimum, the upgrade to Creo offers the same product capabilities as the customer has today, and in many cases, adds new capabilities.
As part of the release of Creo 1.0, we’ll publish a ‘product mapper’ to detail every product, package, and extension and how it maps to Creo. Mike discusses the approach to protecting a customer’s existing investment in the second part of this video FAQ.2. How much will it cost (in both initial charges and annual maintenance fees) to upgrade each Pro/Engineer or CoCreate user?
There is a no cost upgrade for existing maintenance customers to each target Creo app, extension, or package. There are no increases in annual maintenance fees when the customer selects the no cost upgrade.
3. When will the Creo apps have all the equivalent capabilities of Pro/Engineer Wildfire 5?
PTC is committed to protecting the investment customers have already  made, and all data, working methods, and capabilities in Creo Parametric are equivalent to or deliver more than the capabilities found in Creo Elements/Pro 5 (Pro/ENGINEER Wildfire 5) today.
4. How consistent are the user interfaces across all the Creo apps?
While the Creo apps are standalone programs, they have a common look and feel for key areas. The Ribbon presentation is common across all Creo apps, and when commands are common (like File Open, and Close, for example) they are presented in the same way and in the same place.
5. Will all changes made using direct-modeling techniques be represented as dimension-driven features in Creo Parametric? Or will changes made with direct modeling have to be recreated in the parametric program?
Changes made in the direct modeling approach do not have to recreated in the parametric approach;  all changes made in the Direct Modeling app are simply represented as additional changes (features) in the model when it is viewed in the parametric modelling app.  The user of the parametric app can choose to either  accept, and incorporate these changes permanently in the model (by persisting the new features in the model), or review them and reject them entirely.
6. Are there direct edits that will cause parametric features previously created to fail?
No. All changes made via a direct modeling approach can be captured within the parametric model without a failure.
7. What changes to the company’s Windchill PDM or Intralink software will be required to support Creo?
Creo 1.0 apps are compatible with Windchill 9.1 M062 and 10.0.
8. How much retraining will be required to use Creo?
For existing users of Creo Elements/Pro (formerly Pro/ENGINEER), they should think of this upgrade as they would have a significant release of Pro/ENGINEER in the past.  Many companies are planning ½ to 1 day training.
发表于 2011-6-8 10:59:46 | 只看该作者
还没中文的
发表于 2011-6-8 11:48:37 | 只看该作者
硬翻译一下,凑合着看了,呵呵
1。什么会从克里奥元素(又名野火5 M080)升级包路径克里奥应用套件?
克里奥每个元件产品,包装和推广有升级到克里奥,例如,与客户克里奥元素/赡养Pro有选择升级到克里奥参数,与克里奥元素/临基金会将有一个提升客户路径到相应的克里奥参数功能包,等等。至少,对克里奥升级提供相同的产品功能为客户今天,在许多情况下,增加新的功能。
截至克里奥1.0版本的一部分,我们将发布的产品映射器'细节每一件产品,包装和推广,以及它如何映射到克里奥。迈克讨论的方法来保护该视频FAQ.2第二部分客户的现有投资。它的成本是多少(在初始费用及每年的维修费用),升级每个Pro / ENGINEER或CoCreate的用户?
有一个现有客户的维护每个目标克里奥的应用程序,扩展或升级包没有成本。有没有在每年的维护费增加,当客户选择无成本升级。
3。克里奥的应用程序会在何时都在Pro / Engineer Wildfire的5等效能力?
PTC是致力于保护客户的投资已经作出,和所有数据,工作方法和克里奥参数功能相当于或提供比在克里奥元素发现/临5(Pro / ENGINEER野火5)今天的功能更多。
4。如何一致的是用户在所有的应用程序接口克里奥?
虽然应用程序是独立的程序克里奥,他们有一个共同的外观和关键领域的感觉。功能区是常见的表现在所有克里奥应用程序,当命令很常见(如文件打开,关闭,例如)他们以同样的方式,并提出了在同一个地方。
5。将所有更改,使用直接建模技术在克里奥作为参数尺寸驱动功能的代表?或将与直接建模中所做的更改都必须在参数程序重新创建?
在直接建模方法进行的更改不必在重新参数化方法,而在直接建模程序作出一切变化只是作为附加的变化,模型(功能)的代表时,在参数化建模应用效果。的参数化应用程序用户可以选择接受,并纳入本模型(模型中所坚持的新功能),这些更改永久,或审查他们,他们完全拒绝。
6。是否有直接编辑,这将导致以前创建失败参数的功能?
不,所有通过直接建模方法所做的更改可以被捕获在参数模型,没有失败。
7。什么样的变化对公司的Windchill PDM或INTRALINK能软件将需要支持克里奥?
克里奥与Windchill 1.0的应用程序是9.1 M062和10.0兼容。
8。多少培训将被要求使用克里奥?
对于现有的用户克里奥元/专业版(原临/工程师),他们认为应此升级,因为他们有一个Pro / ENGINEER的过去显着释放。许多公司正计划半到1天的培训。
发表于 2011-6-15 01:19:11 | 只看该作者
对在线翻译表示围观
GMT+8, 2025-4-20 05:45 , Processed in 0.027925 second(s), 11 queries , Gzip On, Redis On.
