查看: 16572|回复: 6
【分享】【资料】AUTOCAD的专业工具箱EXPRESS V1.9
发表于 2002-6-17 11:12:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AUTOCAD r14版带了一个BONUS:EXPRESS;
后续的版本就没有提供;
现在有了EXPRESS V1。9是针对ACAD2000后续的版本开发的
发表于 2002-6-17 11:13:11 | 只看该作者
AutoCAD Express Tools Vol. 1-9
The AutoCAD Express Tools are a library of over 80 productivity tools designed to help you extend the power of AutoCAD. They are easy to use, easily integrated into your menus and toolbars, and cover a wide range of AutoCAD functions, including layer management, dimensioning, drawing, object selection, and object modification.
发表于 2002-6-17 11:13:28 | 只看该作者
Benefits Features
Extend your AutoCAD desktop with the most requested, most popular design tools and add-ons available today.
Express Tools work with all AutoCAD 2002, 2000i and 2000-based products and are simple to deploy in your design environment.
Each tool can operate independent of the rest, so training is a breeze! You decide which tools to use and support.
发表于 2002-6-17 11:14:03 | 只看该作者
FEATURE:
Arc-Aligned Text - Places text along an arc.
Reactive Text - Reactive text (RText) objects are displayed the same way normal Text or MText objects are displayed, but the source for the text is either an external text file or the value of a DIESEL expression.
Text Mask - Masks out other geometry behind a Text or MText object.
Over 75 more tools!
发表于 2002-6-17 11:15:59 | 只看该作者
正版售价:149美元
发表于 2006-6-23 20:23:23 | 只看该作者
俺太穷,用不起怎么办。
发表于 2006-6-24 08:46:19 | 只看该作者
晕!!!楼猪不厚道,这东西每个2004安装源程序都带的,只是很多人根本就没注意到罢了,
你别在这里拿出来唬人!
GMT+8, 2025-7-31 18:41 , Processed in 0.121861 second(s), 12 queries , Gzip On, Redis On.
