查看: 17524|回复: 1
[求助] UF_SF_create_ugs_2d_mesh求助!!!
发表于 2011-7-14 15:59:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是我的原程序!
int error=1;
        tag_t scenario;
         error=UF_SF_create_scenario("Scenario_1.sim",&scenario);
             tag_t part_tag;
                 int type;
                 tag_t object=NULL_TAG;
                 tag_t face=NULL_TAG;
                 int subtype;
                 int i=0;
                 tag_t bodys[100];
                 tag_t solid1;
                 char str[50];
         part_tag=UF_PART_ask_display_part();
                 do{
                         UF_OBJ_cycle_objs_in_part( part_tag,UF_solid_type, &face);
                         UF_OBJ_ask_type_and_subtype(face,&type,&subtype);
                         if(type==70 && subtype==UF_solid_face_subtype && face!=NULL_TAG )
                                 bodys[i]=face;
                                 i++;
                 }while(face!= NULL_TAG);
    UF_SF_ugs_2d_mesh_parms_t  mesh_parms;
        int count = 1 ;
        //tag_t scenario;
        //int error=1;
        tag_t mesh_tag ;
        (mesh_parms).element_type = UF_SF_UGS_MESHER_quad4;
        (mesh_parms).element_size = 1;
        (mesh_parms).edge_match_tolerance = 0.508;
        (mesh_parms).format_mesh = TRUE;
        (mesh_parms).attempt_quad_mapping = TRUE;
        (mesh_parms).split_poor_quads = TRUE;
        (mesh_parms).maximum_quad_warp = 2.0;
        (mesh_parms).midnode_option = UF_SF_UGS_MESHER_mixed_midnodes;
        (mesh_parms).maximum_midnode_jacobian = 3.0;
        (mesh_parms).minimum_face_angle = 20.0;
        (mesh_parms).surf_mesh_size_variation  = 0;
        (mesh_parms).mesh_transition  = 1;
        (mesh_parms).mesh_method  = 0;
//error=UF_SF_create_scenario("Scenario_1.sim",&scenario);
error = UF_SF_create_ugs_2d_mesh(&mesh_parms, count, &bodys[0], &mesh_tag);
if (error != 0) uc1601("错误",1);
         UF_SF_display_mesh(mesh_tag);
网格出不来,编译是对的,请高手帮忙!
发表于 2011-8-4 16:31:58 | 只看该作者
你好,UF_SF_create_ugs_2d_mesh这个问题你现在解决了吗?我现在也遇到了这个问题,如果你已经搞定了,希望能得到你的帮助,再次先谢过了,如果你还没解决,那加我QQ--406107431我们一起探讨下吧
GMT+8, 2025-4-19 23:30 , Processed in 0.020612 second(s), 14 queries , Gzip On, Redis On.
