查看: 16353|回复: 8
MY MPA ANSYS2
发表于 2003-8-21 10:52:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Release Level: 6.0
SD097-huer_adv
Part Name: SD097-huer
Material Supplier: Eastman Chemical Products
Material Grade: Eastar PETG 6763
Max Injection Pressure: 140.00 MPa
Mold Temperature: 30.00 deg.C
Melt Temperature: 265.00 deg.C
Model Suitability: Part model was highly suitable for analysis.
SD097-huer_adv
Moldability: Your part may be difficult to fill and part quality may be unacceptable.
View the Confidence of Fill plot and use the Dynamic Adviser to get help on how to improve the filling of the part.
Confidence: Medium
Injection Time: 1.27 sec
Injection Pressure: 124.72 MPa
Weld Lines: Yes
Air Traps: Yes
Shot Volume (cavity, runner): 226.65 cu.cm ( 155.57, 71.09 )
Filling Clamp Force: 269.33 tonne
Packing Clamp Force Estimate @20%: ( 24.94 )MPa 198.91 tonne
Packing Clamp Force Estimate @80%: ( 99.78 )MPa 795.62 tonne
Packing Clamp Force Estimate @120%: ( 149.67 )MPa 1193.43 tonne
Clamp Force Area: 781.95 sq.cm
Cycle Time: 17.38 sec
Warnings:
我的一个零件材料为改性PETG,此零件加工要求高,产量大,但产品长期存在应力开裂问题,但我把进胶位置的零件壁厚处的从1.5MM加厚到2.5MM后,此处开列问题解决;
发表于 2003-8-21 10:52:48 | 只看该作者
发表于 2003-8-21 10:53:16 | 只看该作者
发表于 2003-8-21 10:53:45 | 只看该作者
发表于 2003-8-21 10:54:11 | 只看该作者
发表于 2003-8-21 10:54:34 | 只看该作者
发表于 2003-8-21 10:55:17 | 只看该作者
发表于 2003-8-21 10:55:55 | 只看该作者
发表于 2003-8-21 10:57:52 | 只看该作者
GMT+8, 2025-4-10 23:48 , Processed in 0.033500 second(s), 12 queries , Gzip On, Redis On.
