查看: 16017|回复: 0
【分享】Surfcam Tip# 1 Multi Spindle Speed
发表于 2002-6-23 09:54:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Edit your post processor to allow multiple RPM Speed codes for the same tool. (修改你的後處理,讓你能同一把刀,有不同的主軸轉速)
Example : You have several pockets and counter-bores that you wish to do with the same tool but you would prefer to use several RPM speeds for the different features. In order to achieve this you must modify your post processors with 3 new lines of code.
First open the windows explorer and locate your Postform.m file. Normally it can be found in the C:\SURFCAM\Postlib\ directory. Double click the Postform.m file and it should open in a text editor. Scroll down until you get to the infeed section then type in the three lines shown in bright blue below. This must be done to each post in your postform.m file. ( It is always a good Idea to save a backup of your file before you edit it.)
(在surfcam\postlib目錄下,修改postform.m, 找到你要用的那個後處理, 加上 或修改 以下幾行)
Infeed
G[Side] X[H] Y[V] D[DComp] F[FRate]
end
Upon [Speed]
S[Speed]
End
Outfeed
G1 G40 X[H] Y[V]
end
GMT+8, 2025-4-5 05:24 , Processed in 0.040033 second(s), 11 queries , Gzip On, Redis On.
