查看: 16263|回复: 0
DTOL.lsp修正版
发表于 2003-8-26 13:40:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
只增加兩行敘述,DTOL.lsp便可以在輸入上下公差後提示輸入公差的字高。並一次完成較理想的公差標註作業。
增加的敘述:
      setq txth(getreal "\n[$#63384]Tolerance Text High :"))
   與 (setvar "dimtfac" txth)
如須更改上下公差的設定值和字高只須在Comm.:提示下再輸入DTOL即可。
請用文書編輯程式修改原DTOL.lsp。
修正後之DTOL.lsp
(defun c:dtol()
(setq upv(getstring "\n[$#63384]Upper Tolerance :"))
(setq lowerv(getstring "\n[$#63384]Lower Tolerance :"))
(setq txth(getreal "\n[$#63384]Tolerance Text High :"))
(if lowerv
(if (= (substr lowerv 1 1) "+")
(progn
(setq lowerv(atof lowerv))
(setq lowerv(- 0 lowerv))
(setq lowerv (abs (atof lowerv)))
(setq upv(atof upv))
(setvar "dimtol" 1)
(setvar "dimalttz" 1)
(setvar "dimtp" upv)
(setvar "dimtm" lowerv)
(command "dim" "update" pause "" "exit")
(setvar "dimtol" 0)
GMT+8, 2025-4-21 04:57 , Processed in 0.019097 second(s), 12 queries , Gzip On, Redis On.
