查看: 18186|回复: 4
【求助】NC后处理器
发表于 2002-6-28 16:20:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
每次选择<应用程序><NC后处理器>就会出现下面出错对话框。请问各位高手应该怎么做?
发表于 2002-6-28 16:27:02 | 只看该作者
你可能是用P-IV處理器的微機
https:8.106.209.19/cgi-bin/ut/topic_show.cgi?id=1062&pg=9&bpg=5
https:8.106.209.19/cgi-bin/ut/topic_show.cgi?id=3858&h=1&bpg=9&age=0
发表于 2002-6-28 19:12:55 | 只看该作者
是的,但我去下载
https://idesign2002.com/training/cam/GPost/NCJLIBS_P4_Fix.exe
怎么没了.请sinderal 重传好吗?或M给我,zhangyubincn@yahoo.com.cn
有劳sindera 版主,谢谢!!!
发表于 2002-6-28 20:55:40 | 只看该作者
我的那個檔案要12.1MB.
看下列帖,去 DownLoad, 你的積分不夠,看不到BOBY的帖子
Description
On a Pentium 4 W2K workstation, selecting #Applications #NC Post Processor in Pro/ENGINEER causes a PROGRAM ERROR dialog box to appear with the following message:
"javaw.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created."
On a Pentium 4 NT workstation, selecting #Applications #NC Post Processor in Pro/ENGINEER causes a javaw.exe-APPLICATION ERROR dialog box to appear with the following message:
"The instruction at "0x500bf974" referenced memory at "0x00000e7f". The memory could not be "read"."
In both these cases GPOST will not launch.
Alternate Technique
Download Java Runtime Environment 1.2.2_008 from https://java.sun.com/products/jdk/1.2/jre/download-windows.html and install it in the following directory:
\i486_nt\gpost\ncjlibs\Jre\1.2
Reboot the workstation. GPOST can then be launched by selecting #Applications #NC Postprocessor.
Resolution
This issue will be resolved in a future release of Pro/ENGINEER.
发表于 2002-6-29 17:22:04 | 只看该作者
谢谢 sinderal 做好了!太感谢了.
GMT+8, 2025-4-19 18:45 , Processed in 0.024149 second(s), 11 queries , Gzip On, Redis On.
