查看: 16070|回复: 0
【资料】UG自带的函数
发表于 2002-6-29 02:07:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Name
  Description
abs
  Absolute Value, abs(x) = |x|
acos
  Arc Cosine, acos(x) = arc cos(x), (result in radians)
asin
  Arc Sine, asin(x) = arc sin(x), (result in radians)
atan
  Arc Tangent, atan(x) = arc tan(x), (result in radians)
atan2
  Arc Tangent, atan2(x, y) = arc tan(x / y), (result in radians)
ceil
  Ceiling, ceil(x) = x is a real number, function returns closest integer greater than or equal to x if a=ceil(.1), a evaluates to 1
cos
  Cosine, cos(x) = cos(x), (x must be in degrees)
cosh
  Hyperbolic Cosine, cosh(x) = cosh(x)
deg
  Degree Conversion, deg(x) converts radians to degrees.
exp
  Exponential, exp(x) = ex
fact
  Factorial, fact(x) = x!
floor
  Floor, floor(x) = x is a real number, function returns closest integer less than or equal to x if a=floor(.1), a evaluates to 0
hypot
  Hypotenuse, hypot(x, y) = /x2 + y2
log
  Natural Logarithm, log(x) = ln (x) = loge (x)
log10
  Common Logarithm, log10(x) = log10(x)
rad
  Radian Conversion, rad(x) converts degrees to radians
sin
  Sine, sin(x) = sin(x), (x must be in degrees)
sinh
  Hyperbolic Sine, sinh(x) = sinh(x)
sqrt
  Square Root, sqrt (x) = /x
tan
  Tangent, tan(x) = tan(x), (x must be in degrees)
tanh
  Hyperbolic Tangent, tanh(x) = tanh(x)
trnc
  Truncate, trnc(x) removes any fractional portion (all digits to the right of the decimal point) from the number x
pi()
  Takes no arguments and returns the value of pi
GMT+8, 2025-4-28 23:49 , Processed in 0.021683 second(s), 10 queries , Gzip On, Redis On.
