查看: 16343|回复: 1
【分享】Pro/ENGINEER Tips and Tricks
发表于 2002-7-2 17:29:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Tips & Tricks – Goals
  A Bunch of Things You Probably Knew
  Some Things You Didn’t Know
  Maybe One Thing That Works Great
      That You Didn’t Know
Tips & Tricks – General ProE
Middle Mouse Button to Accept
Right Mouse Button for Pop-up Redefine/Info/Etc.
File Preview
Use Fast Hidden Line Removal
Renaming Features
Display Datums While Spinning
Component Display States
Explode States
Assembly – move component using CTRL-ALT
Tips & Tricks – Model Tree
Right Mouse Features from Model Tree
Drag and Drop Re-Order
Drag and Drop Insert Mode
Right Mouse in Model Tree
Custom Model Tree Setups
Rename/Modify Features in Model Tree
Tips & Tricks – Sketcher
Cheat Sheet (Handout)
Middle Mouse Button to get Pick Arrow
Configure Screen & Icons
Mapkeys – Create & Iconize
Tips & Tricks – Drawings (Clarity)
Z-Clipping (also decreases repaint time)
Member Display
Relating Draft Items to a View
Quilt Hidden Line Removal
Fonts
Use @o to attach leader to multi-line text
Tips & Tricks – Drawings (Ease of Use)
Right Mouse Modify
Align Views / Unalign Projected Views
Copy from other Drawing
Template Drawings
Word Wrap (2001)
Tips & Tricks – Drawings (Speed)
General Tips:
Turn off datum displays
Work in wireframe
Set auto_regen_views to no
No View Open (open_simplified_rep_by_default=yes)
Erase/Resume Views
Snapshot of View
Merge Drawings
发表于 2002-7-2 20:29:51 | 只看该作者
斑竹,你的技巧有些我觉的很对,有几个没看懂。能否详细点?谢谢!
GMT+8, 2025-4-21 20:59 , Processed in 0.025935 second(s), 12 queries , Gzip On, Redis On.
