查看: 16097|回复: 3
【求助】How to set Round Shape Cross-Section?
发表于 2002-7-5 16:49:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位,Pro/e中可否设置属性,使得我们在做Round时可以采用Conic作为其Cross-section  ?
By default,the system creates a circular cross-section of the round defined with a true radius,but you can drive the cross-section to use a conic section. A round with a conic section uses two values to drive its shape:a radius value and a conic parameter(rho) value.
发表于 2002-7-5 18:32:28 | 只看该作者
用曲面成型方式
发表于 2002-7-5 19:24:48 | 只看该作者
Select the option available in "Round Shape" when you want to create round feature.
发表于 2002-7-8 09:20:13 | 只看该作者
谢谢!
请问ccf: where is the option "Round Shape:?
and ,who can give us some examples about Conic Cross-section Round? Thanks
GMT+8, 2025-4-21 14:46 , Processed in 0.021727 second(s), 12 queries , Gzip On, Redis On.
