查看: 15896|回复: 0
【推荐】 UGMerge
发表于 2002-7-5 17:12:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这东西有谁会用到阿?
The company Widgets Inc. uses a custom ug_english.dat file. After installing UG, they modify ug_english.dat to their liking and place it in r:\ug_shared\ugs180. Everyone in the company uses the same plot_queue HP650_WIDTH except Jan, who usually plots color and prefers the default queue HP650_COLOR. In this case, Administrator would place a text file named ug_english.dat in Jan's home drive and make the following entry in this file:
UG_defaultPlotQueueName: HP650_COLOR
When Jan starts UG via a custom batch file, UGMerge will be executed, merge the two .dat files creating a new .dat file and place that file in the local UGS folder, overwriting the existing ug_english.dat file. That new, local .dat file will now have the appropriate default plot_queue whilst all other users will be using the default plot_queue defined in the global definition file.
GMT+8, 2025-4-26 18:07 , Processed in 0.020637 second(s), 11 queries , Gzip On, Redis On.
