查看: 17172|回复: 0
Proe特征
发表于 2011-8-16 16:11:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Proe二次开发中使用到ProFeatureTypeGet()函数,但对该函数的第二个参数不是太了解,在ProFeatType.h 头文件中有很多,那位大侠给详细说明下,不胜感激!
#ifndef PROFEATTYPEH#define PROFEATTYPEH#define PRO_FEAT_FIRST_FEAT   0       /* This feature is a protrusion */#define PRO_FEAT_HOLE                911#define PRO_FEAT_SHAFT                912#define PRO_FEAT_ROUND                913#define PRO_FEAT_CHAMFER        914#define PRO_FEAT_SLOT                915#define PRO_FEAT_CUT                916#define PRO_FEAT_PROTRUSION        917#define PRO_FEAT_NECK                918#define PRO_FEAT_FLANGE                919#define PRO_FEAT_RIB                920#define PRO_FEAT_EAR                921#define PRO_FEAT_DOME                922#define PRO_FEAT_DATUM                923#define PRO_FEAT_LOC_PUSH        924/* #define PRO_FEAT_PATTERN        925 */#define PRO_FEAT_UDF          925#define PRO_FEAT_DATUM_AXIS   926#define PRO_FEAT_DRAFT        927#define PRO_FEAT_SHELL        928#define PRO_FEAT_DOME2        929#define PRO_FEAT_CORN_CHAMF        930#define PRO_FEAT_DATUM_POINT        931#define PRO_FEAT_IMPORT        932#define PRO_FEAT_IGES                PRO_FEAT_IMPORT /* Don't use PRO_FEAT_IGES */#define PRO_FEAT_COSMETIC     933#define PRO_FEAT_ETCH         934#define PRO_FEAT_MERGE        935#define PRO_FEAT_MOLD         936#define PRO_FEAT_SAW          937#define PRO_FEAT_TURN         938#define PRO_FEAT_MILL         939#define PRO_FEAT_DRILL        940#define PRO_FEAT_OFFSET       941#define PRO_FEAT_DATUM_SURF   942#define PRO_FEAT_REPLACE_SURF 943#define PRO_FEAT_GROOVE       944#define PRO_FEAT_PIPE         945#define PRO_FEAT_DATUM_QUILT  946#define PRO_FEAT_ASSEM_CUT    947#define PRO_FEAT_UDF_THREAD   948#define PRO_FEAT_CURVE        949#define PRO_FEAT_SRF_MDL      950#define PRO_FEAT_WALL         952#define PRO_FEAT_BEND         953#define PRO_FEAT_UNBEND       954#define PRO_FEAT_CUT_SMT      955#define PRO_FEAT_FORM         956#define PRO_FEAT_THICKEN      957#define PRO_FEAT_BEND_BACK    958#define PRO_FEAT_UDF_NOTCH    959#define PRO_FEAT_UDF_PUNCH    960#define PRO_FEAT_INT_UDF      961#define PRO_FEAT_SPLIT_SURF   962#define PRO_FEAT_GRAPH        963#define PRO_FEAT_SMT_MFG_PUNCH 964#define PRO_FEAT_SMT_MFG_CUT  965#define PRO_FEAT_FLATTEN      966#define PRO_FEAT_SET          967        /* PRO_FEAT_SET & PRO_FEAT_VDA are old types */#define PRO_FEAT_VDA          968#define PRO_FEAT_SMT_MFG_FORM 969#define PRO_FEAT_SMT_PUNCH_PNT 970#define PRO_FEAT_LIP          971#define PRO_FEAT_MANUAL       972#define PRO_FEAT_MFG_GATHER        973#define PRO_FEAT_MFG_TRIM        974#define PRO_FEAT_MFG_USEVOL   975#define PRO_FEAT_LOCATION     976#define PRO_FEAT_CABLE_SEGM   977#define PRO_FEAT_CABLE        978#define PRO_FEAT_CSYS         979#define PRO_FEAT_CHANNEL      980#define PRO_FEAT_WIRE_EDM     PRO_FEAT_SAW#define PRO_FEAT_AREA_NIBBLE        981#define PRO_FEAT_PATCH        982#define PRO_FEAT_PLY          983#define PRO_FEAT_CORE         984#define PRO_FEAT_EXTRACT        985#define PRO_FEAT_MFG_REFINE   986#define        PRO_FEAT_SILH_TRIM        987#define PRO_FEAT_SPLIT        988#define        PRO_FEAT_EXTEND        989#define PRO_FEAT_SOLIDIFY     990#define PRO_FEAT_INTERSECT    991#define PRO_FEAT_ATTACH       992#define PRO_FEAT_XSEC                993#define        PRO_FEAT_UDF_ZONE        994#define        PRO_FEAT_UDF_CLAMP        995#define PRO_FEAT_DRL_GRP        996#define PRO_FEAT_ISEGM        997#define PRO_FEAT_CABLE_COSM        998#define        PRO_FEAT_SPOOL        999#define PRO_FEAT_COMPONENT   1000#define        PRO_FEAT_MFG_MERGE   1001#define        PRO_FEAT_FIXSETUP    1002#define        PRO_FEAT_SETUP        PRO_FEAT_FIXSETUP#define        PRO_FEAT_FLAT_PAT    1003#define PRO_FEAT_CONT_MAP    1004#define PRO_FEAT_EXP_RATIO   1005#define PRO_FEAT_RIP         1006#define PRO_FEAT_OPERATION   1007#define PRO_FEAT_WORKCELL    1008#define PRO_FEAT_CUT_MOTION  1009#define PRO_FEAT_PUNCH_QUILT 1010#define PRO_FEAT_BLD_PATH    1013#define PRO_FEAT_CUSTOMIZE   PRO_FEAT_BLD_PATH#define PRO_FEAT_DRV_TOOL_SKETCH  1014#define PRO_FEAT_DRV_TOOL_EDGE    1015#define PRO_FEAT_DRV_TOOL_CURVE   1016#define PRO_FEAT_DRV_TOOL_SURF    1017#define PRO_FEAT_MAT_REMOVAL 1018#define PRO_FEAT_TORUS       1019#define PRO_FEAT_PIPE_SET_START  1020#define PRO_FEAT_PIPE_PNT_PNT    1021#define PRO_FEAT_PIPE_EXT        1022#define PRO_FEAT_PIPE_TRIM       1023#define PRO_FEAT_PIPE_FOLL       1024#define PRO_FEAT_PIPE_JOIN       1025#define PRO_FEAT_AUXILIARY    1026#define PRO_FEAT_PIPE_LINE       1027#define PRO_FEAT_LINE_STOCK      1028#define PRO_FEAT_SLD_PIPE           1029#define PRO_FEAT_BULK_OBJECT     1030#define PRO_FEAT_SHRINKAGE              1031#define PRO_FEAT_PIPE_JOINT           1032#define PRO_FEAT_PIPE_BRANCH           1033#define PRO_FEAT_DRV_TOOL_TWO_CNTR        1034#define PRO_FEAT_SUBHARNESS      1035#define PRO_FEAT_SMT_OPTIMIZE    1036#define PRO_FEAT_DECLARE         1037#define PRO_FEAT_SMT_POPULATE    1038#define PRO_FEAT_OPER_COMP       1039#define PRO_FEAT_MEASURE         1040#define PRO_FEAT_DRAFT_LINE      1041#define PRO_FEAT_REMOVE_SURFS    1042#define PRO_FEAT_RIBBON_CABLE    1043#define PRO_FEAT_ATTACH_VOLUME   1046#define        PRO_FEAT_BLD_OPERATION   1047#define PRO_FEAT_UDF_WRK_REG     1048#define PRO_FEAT_SPINAL_BEND     1049#define PRO_FEAT_TWIST           1050#define PRO_FEAT_FREE_FORM       1051#define PRO_FEAT_ZONE            1052#define PRO_FEAT_WELDING_ROD     1053#define PRO_FEAT_WELD_FILLET     1054#define PRO_FEAT_WELD_GROOVE     1055#define PRO_FEAT_WELD_PLUG_SLOT  1056#define PRO_FEAT_WELD_SPOT       1057#define PRO_FEAT_SMT_SHEAR       1058#define PRO_FEAT_PATH_SEGM       1059#define PRO_FEAT_RIBBON_SEGM     1060#define PRO_FEAT_RIBBON_PATH     PRO_FEAT_PATH_SEGM#define PRO_FEAT_RIBBON_EXTEND   PRO_FEAT_RIBBON_SEGM#define PRO_FEAT_ASMCUT_COPY     1061#define PRO_FEAT_DEFORM_AREA     1062#define PRO_FEAT_RIBBON_SOLID      1063#define PRO_FEAT_FLAT_RIBBON_SEGM  1064#define PRO_FEAT_POSITION_FOLD     1065#define PRO_FEAT_SPRING_BACK       1066#define PRO_FEAT_BEAM_SECTION      1067#define PRO_FEAT_SHRINK_DIM        1068/* #1069 unused */#define PRO_FEAT_THREAD            1070#define PRO_FEAT_SMT_CONVERSION    1071#define PRO_FEAT_CMM_MEASSTEP      1072#define PRO_FEAT_CMM_CONSTR        1073#define PRO_FEAT_CMM_VERIFY        1074#define PRO_FEAT_CAV_SCAN_SET      1075#define PRO_FEAT_CAV_FIT           1076#define PRO_FEAT_CAV_DEVIATION     1077#define PRO_FEAT_SMT_ZONE          1078#define PRO_FEAT_SMT_CLAMP         1079#define PRO_FEAT_PROCESS_STEP      1080#define PRO_FEAT_EDGE_BEND         1081       #define PRO_FEAT_DRV_TOOL_PROF     1082#define PRO_FEAT_EXPLODE_LINE      1083#define PRO_FEAT_GEOM_COPY         1084#define PRO_FEAT_ANALYSIS          1085#define PRO_FEAT_WATER_LINE        1086#define PRO_FEAT_UDF_RMDT          1087#define PRO_FEAT_VOL_SPLIT         1088#define PRO_FEAT_WLD_EDG_PREP      1089#define PRO_FEAT_SMM_OFFSET        1090 #define PRO_FEAT_SMM_MATREM        1091#define PRO_FEAT_SMM_COSMETIC      1092#define PRO_FEAT_SMM_APPROACH      1093#define PRO_FEAT_SMM_SLOT          1094#define PRO_FEAT_SMM_SHAPE         1095#define PRO_FEAT_IPM_QUILT         1096  #define PRO_FEAT_DRVD              1097#define PRO_FEAT_SMT_CRN_REL       1098#define PRO_FEAT_SLDBEND           1101#define PRO_FEAT_FLATQLT           1102#define PRO_FEAT_DRV_TOOL_TURN           1103#define PRO_FEAT_GROUP_HEAD        1104#define PRO_FEAT_FR_SYS            1105#define PRO_FEAT_HULL_COMPT        1106#define PRO_FEAT_REFERENCE         1107#define PRO_FEAT_SHELL_EXP         1108#define PRO_FEAT_FREEFORM          1109     /* Style feature */#define PRO_FEAT_KERNEL                   1110#define PRO_FEAT_WELD_PROCESS      1111#define PRO_FEAT_HULL_REP_TMP      1112#define PRO_FEAT_INSULATION        1113#define PRO_FEAT_SLD_PIP_INSUL     1114#define PRO_FEAT_SMT_EXTRACT       1115#define PRO_FEAT_ASSY_MERGE        1116  #define PRO_FEAT_DS_OPTIMIZE       1117#define PRO_FEAT_COMP_INTERFACE    1118#define PRO_FEAT_OLE               1119#define PRO_FEAT_TERMINATOR        1120#define PRO_FEAT_WLD_NOTCH         1121  #define PRO_FEAT_ASSY_WLD_NOTCH    1122  #define PRO_FEAT_ROUTE_MANAGER     1123#define PRO_FEAT_HULL_WLD_NOTCH    1124#define PRO_FEAT_SMM_SLIT          1125#define PRO_FEAT_SMM_HOLE          1126#define PRO_FEAT_SMM_NEST          1127#define PRO_FEAT_SMM_GROOVE        1128#define PRO_FEAT_SMM_ETCH          1129#define PRO_FEAT_ROUTE_PATH        1130#define PRO_FEAT_HULL_PLATE        1211#define PRO_FEAT_HULL_HOLE            1212#define PRO_FEAT_HULL_CUTOUT       1213#define PRO_FEAT_HULL_STIFFENER    1214#define PRO_FEAT_HULL_BEAM         1215#define PRO_FEAT_HULL_ENDCUT       1216#define PRO_FEAT_HULL_WLD_FLANGE   1217#define PRO_FEAT_HULL_COLLAR       1218#define PRO_FEAT_HULL_DRAW         1219#define PRO_FEAT_HULL_BRACKET      1220#define PRO_FEAT_HULL_FOLDED_FLG   1221#define PRO_FEAT_HULL_BLOCK        1222 #define PRO_FEAT_HULL_BLOCK_DEF    1223 #define PRO_FEAT_HULL_SPLIT_BOUND  1224#define PRO_FEAT_SUPERQUILT        1225#define PRO_FEAT_MLD_SLIDER        1226#define PRO_FEAT_HULL_PAD          1227#define PRO_FEAT_ROUTE_SPOOL       1228#define PRO_FEAT_GLOBAL_MODEL      1229#define PRO_FEAT_HULL_MITRE        1230#define PRO_FEAT_HULL_SLOTCUT      1231#define PRO_FEAT_PATTERN_HEAD      1232#define PRO_FEAT_FLEX_MUTATOR      1233#define PRO_FEAT_ANNOTATION        1234#define PRO_FT_GR_REMOVE_SURFS     1235#define PRO_FT_GR_TAPER_EXTR       1236#define PRO_FT_GR_TOOL_COMP        1237#define PRO_FEAT_GEN_MERGE         1238#define PRO_FEAT_PM_DAMPER         1239#define PRO_FEAT_PM_SPRING         1240#define PRO_FEAT_AUTO_ROUND        1241#define PRO_FEAT_DSGNT_AREA        1242#define PRO_FEAT_RM_SURF           1243#define PRO_FEAT_ARTWORK           1244#define PRO_FEAT_USER_FEAT         2000  #endif
GMT+8, 2025-2-2 02:01 , Processed in 0.025646 second(s), 12 queries , Gzip On, Redis On.
