查看: 15829|回复: 1
高手请看一下吧!
发表于 2003-9-25 22:31:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我是一名新手,现在从别的地方拷贝了一个IDEAS模型,但是不知怎么打开该模型。
该模型有如下的提示操作步骤:
work to import PKG file to IDEAS
1、please copy PKG file to CAD handset.
2、please open the model file.
3、please choose the " import" ( on the screen at the upper right)
4、the form opens so choose "ideas library data " in it and click "ok".
5、then the I-DEAS IMPORT form opens and specify PKG file in drive to file  section.
6、please specify project library and click import button.
the way of taking out a data to model file
1、please choose command of "get from library".
2、taking out form from project is shown so please choose the data for taking out.
3、please specfiy the way of taking out(checkout, copy etc.)
4、please click the "ok" button.
请问高手解析一下上面英文提示操作是什么意思, 小弟先在这向你致意。
发表于 2003-9-25 23:12:11 | 只看该作者
按下面步驟:
點菜File-->Import...-->選"I-DEAS Libray Data"-->點OK-->
在file欄中輸入 pkg 文件名(含路徑)-->回車-->接著點”creat missing"按鈕-->再點"Import..."按鈕。零件就會輸入到library中
取出零件:點”manage bins"圖標-->點“gets item from library"按鈕
--->選中需要的零件,點 "check out"按鈕,點ok
零件到bin 中后即可隨時 get from bin
GMT+8, 2025-4-20 23:11 , Processed in 0.021134 second(s), 12 queries , Gzip On, Redis On.
