查看: 16204|回复: 4
【求助】about pro/e shade color
发表于 2002-7-16 16:02:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  why  can't i  modify the color of the shade part in pro/e 2001400 version,help?thanks!
发表于 2002-7-17 14:35:22 | 只看该作者
why aren't you try to modify: view>model setup>colors and apperances?
发表于 2002-7-17 17:04:19 | 只看该作者
i think u don't what i mean, i try the step u refered already,but it doesn't work;and pop-up a message"allowed numder of colors exceeded"; i also do some modification in the relative setup in config.pro,still not work?
发表于 2002-7-17 18:40:08 | 只看该作者
There is a option in "config.pro" to define the number of colors
in the "color.map" file.
oh i find it, the option is "number_user_colors" .
you may set it to 120 or above.
发表于 2002-7-18 10:13:12 | 只看该作者
bamboo,thanks;but it still doesn't work. My pro/e is 20014000(not D version),i set the item"number_user_color" to 255,"color_ramp_size" to 255;and also the"pro_colormap_path" to " /proe2001/text/hull data/hull_color_file.map"(for i could not find the file"color.map"as u refered).the popup window still on(my lisence is from foreign country).
GMT+8, 2025-4-22 07:45 , Processed in 0.034130 second(s), 12 queries , Gzip On, Redis On.
