【求助】l离谱的分析结果
发表于 2003-10-19 22:15:13 | 只看该作者
QianFD,你的单位不一样,实际上结果是一样的
各位先把态度问题放在一边,我那个收敛的问题谁给我解答啊
22
发表于 2003-10-20 03:42:13 | 只看该作者
我用PRO/M分析了一下,没考虑非线性变形的因素。已经收敛了。
Pro/MECHANICA STRUCTURE Version 23.3(311)
Summary for Design Study "Analysis1"
Sun Oct 19, 2003   12:35:59
Run Settings
    Memory allocation for block solver: 96.0
Checking the model before creating elements...
These checks take into account the fact that AutoGEM will
automatically create elements in volumes with material
properties, on surfaces with shell properties, and on curves
with beam section properties.
    Generate elements automatically.
Checking the model after creating elements...
No errors were found in the model.
Pro/MECHANICA STRUCTURE Model Summary
    Principal System of Units: millimeter Newton Second (mmNs)
    Length:          mm
    Force:           N
    Time:            sec
    Temperature:     C
    Model Type: Three Dimensional
    Edges:                 307
    Faces:                 350
    Springs:                 0
    Masses:                  0
    Beams:                   0
    Shells:                  0
    Solids:                131
    Elements:              131
Standard Design Study
Static Analysis "Analysis1":
    Convergence Method: Multiple-Pass Adaptive
    Plotting Grid:      4
    Convergence Loop Log:                         (12:36:03)
    >> Pass  1 <<
          Calculating Element Equations           (12:36:03)
             Total Number of Equations:     222
             Maximum Edge Order:              1
          Solving Equations                       (12:36:03)
          Post-Processing Solution                (12:36:03)
          Calculating Disp and Stress Results     (12:36:03)
          Checking Convergence                    (12:36:04)
             Elements Not Converged:        131
             Edges Not Converged:           307
             Local Disp/Energy Index:    100.0%
             Global RMS Stress Index:    100.0%
          Resource Check                          (12:36:04)
             Elapsed Time     (sec):       5.70
             CPU Time         (sec):       5.08
             Memory Usage      (kb):     142325
             Wrk Dir Dsk Usage (kb):          0
    >> Pass  2 <<
          Calculating Element Equations           (12:36:04)
             Total Number of Equations:    1068
             Maximum Edge Order:              2
          Solving Equations                       (12:36:04)
          Post-Processing Solution                (12:36:04)
          Calculating Disp and Stress Results     (12:36:05)
          Checking Convergence                    (12:36:05)
             Elements Not Converged:         92
             Edges Not Converged:           200
             Global RMS Stress Index:     87.6%
          Resource Check                          (12:36:05)
             Elapsed Time     (sec):       7.02
             CPU Time         (sec):       6.31
             Memory Usage      (kb):     143413
    >> Pass  3 <<
          Calculating Element Equations           (12:36:05)
             Total Number of Equations:    2844
             Maximum Edge Order:              4
          Solving Equations                       (12:36:06)
          Post-Processing Solution                (12:36:07)
          Calculating Disp and Stress Results     (12:36:07)
          Checking Convergence                    (12:36:08)
             Elements Not Converged:         37
             Edges Not Converged:             0
             Local Disp/Energy Index:     46.6%
             Global RMS Stress Index:     17.0%
          Resource Check                          (12:36:08)
             Elapsed Time     (sec):       9.77
             CPU Time         (sec):       8.61
             Wrk Dir Dsk Usage (kb):       1024
    >> Pass  4 <<
          Calculating Element Equations           (12:36:08)
             Total Number of Equations:    5802
             Maximum Edge Order:              5
          Solving Equations                       (12:36:11)
          Post-Processing Solution                (12:36:12)
          Calculating Disp and Stress Results     (12:36:13)
          Checking Convergence                    (12:36:14)
             Elements Not Converged:          4
             Local Disp/Energy Index:     18.5%
             Global RMS Stress Index:      5.2%
          Resource Check                          (12:36:15)
             Elapsed Time     (sec):      16.37
             CPU Time         (sec):      14.46
             Wrk Dir Dsk Usage (kb):       5120
    >> Pass  5 <<
          Calculating Element Equations           (12:36:15)
             Total Number of Equations:    8178
          Solving Equations                       (12:36:20)
          Post-Processing Solution                (12:36:22)
          Calculating Disp and Stress Results     (12:36:24)
          Checking Convergence                    (12:36:25)
             Elements Not Converged:          0
            Local Disp/Energy Index:      7.9%
            Global RMS Stress Index:      8.4%
          RMS Stress Error Estimates:
          Load Set          Stress Error  % of Max Prin Str
          LoadSet1           1.31e-04       1.8% of  7.18e-03
          Resource Check                          (12:36:29)
             Elapsed Time     (sec):      30.22
             CPU Time         (sec):      26.68
             Wrk Dir Dsk Usage (kb):       9216
    The analysis converged to within 10% on
    edge displacement, element strain energy,
    and global RMS stress.
    Total Mass of Model:  4.304894e-05
    Total Cost of Model:  0.000000e+00
    Mass Moments of Inertia about WCS Origin:
      Ixx:  2.22420e-02
      Ixy: -1.32137e-19  Iyy:  4.37664e-02
      Ixz: -2.57498e-19  Iyz: -1.69407e-20  Izz:  2.22420e-02
    Principal MMOI and Principal Axes Relative to WCS Origin:
             Max Prin           Mid Prin           Min Prin
            4.37664e-02        2.22420e-02        2.22420e-02
    WCS X:  0.00000e+00        1.00000e+00        0.00000e+00
    WCS Y:  1.00000e+00        0.00000e+00        0.00000e+00
    WCS Z:  0.00000e+00        0.00000e+00        1.00000e+00
    Center of Mass Location Relative to WCS Origin:
                   ( 3.14817e-16,  2.50000e+00, -8.21475e-16)
    Mass Moments of Inertia about the Center of Mass:
      Ixx:  2.19729e-02
      Ixy: -9.82558e-20  Iyy:  4.37664e-02
      Ixz: -2.57498e-19  Iyz: -1.05350e-19  Izz:  2.19729e-02
    Principal MMOI and Principal Axes Relative to COM:
            4.37664e-02        2.19729e-02        2.19729e-02
    Constraint Set: ConstraintSet1
    Load Set: LoadSet1
       Resultant Load on Model:
          in global X direction:  2.559861e-15
          in global Y direction:  8.563202e-16
          in global Z direction: -2.500000e-02
       Measures:
            Name              Value      Convergence
       max_beam_bending:   0.000000e+00      0.0%
       max_beam_tensile:   0.000000e+00      0.0%
       max_beam_torsion:   0.000000e+00      0.0%
       max_beam_total:     0.000000e+00      0.0%
       max_disp_mag:       2.755566e-06      0.3%
       max_disp_x:        -9.548489e-07      0.1%
       max_disp_y:         1.938210e-08      4.8%
       max_disp_z:        -2.755548e-06      0.3%
       max_prin_mag:       7.180474e-03     16.8%
       max_rot_mag:        0.000000e+00      0.0%
       max_rot_x:          0.000000e+00      0.0%
       max_rot_y:          0.000000e+00      0.0%
       max_rot_z:          0.000000e+00      0.0%
       max_stress_prin:    7.180474e-03     16.8%
       max_stress_vm:      5.333916e-03      0.6%
       max_stress_xx:      4.975084e-03      0.2%
       max_stress_xy:     -1.633257e-04     32.2%
       max_stress_xz:      2.170190e-03     20.2%
       max_stress_yy:      1.603855e-03     33.0%
       max_stress_yz:      3.843751e-04     11.0%
       max_stress_zz:      5.635404e-03     10.2%
       min_stress_prin:   -4.787042e-03      0.2%
       strain_energy:      2.328736e-08      0.3%
Analysis "Analysis1" Completed  (12:36:29)
Memory and Disk Usage:
    Machine Type: Windows NT/x86
    RAM Allocation for Solver (megabytes): 96.0
    Total Elapsed Time (seconds): 30.52
    Total CPU Time     (seconds): 26.83
    Maximum Memory Usage (kilobytes): 143413
    Working Directory Disk Usage (kilobytes): 9216
    Results Directory Size (kilobytes):
    2864 .\Analysis1
    Maximum Data Base Working File Sizes (kilobytes):
    8192 .\Analysis1.tmp\kel1.bas
    1024 .\Analysis1.tmp\oel1.bas
Run Completed
Sun Oct 19, 2003   12:36:29
发表于 2003-10-20 08:14:20 | 只看该作者
我收回我的话!
对不起了斑竹!^_^!
谢谢所有回复的朋友。但是看了所有回复的帖子,感觉问题还是非常的多的。
公司引进了cosmos系统,赶鸭子上架,我学起来非常的吃力!
一般的操作都可以了,因为有正版的中文教程学习。就是分析的结果和一些力的理论知识比较模糊。
看来我应该找一些中学的课本看看吧!
24
发表于 2003-10-20 10:12:19 | 只看该作者
laolidage wrote:
我收回我的话!
  对不起了斑竹!^_^!
  看来我应该找一些中学的课本看看吧!
没什么的,大家在一起就是互相探讨,互相进步的,谢谢你的参与!
建议你看一下材料力学能加深一下力学概念!
25
发表于 2003-10-20 16:58:30 | 只看该作者
支持版主!
26
发表于 2003-10-20 18:34:39 | 只看该作者
laolidage wrote:
  如图为60mm×60mm合金钢框架,内孔50mm×50mm,也就是说四周壁厚为5mm,框架自身的厚度也是5mm。
    我约束一个底面,在对应面加100牛顿的载荷。怎么分析的结果会这么的离谱?
    我们知道,零件最大屈服力等于“当前载荷乘以所计算的最低安全系数”
  那样的话就是100牛顿×113882,那可是上百万公斤呀!这是不可能的。
    请教斑竹是怎么回事?盼回答!!!
首先你加的是压力载荷100 N/m^2, 所以那个面的整体受力是100*(50*5/10^6)=0.025 N,而不是100N。你是基于加载
100 N/M^2的压力载荷进行分析的。
零件最大屈服力等于“当前载荷乘以所计算的最低安全系数” ,我想应该这样算
0.025*113882=2847 N=290 kg,290公斤, 而不是用100*113882。
(我没考虑非线性变形)
27
发表于 2003-10-20 19:19:43 | 只看该作者
下图为施加100N时的VONMISS应力分布图,因此根据合金钢的屈服极限620.4MPa,可以换算得到屈服载荷100*(620.4/20.78)=2986N。
另外从计算结果可以分析出即使在屈服载荷下也只是个小变形,小应变的情况,因此如果需要考虑屈服载荷,就可以不用考虑非线形因素!
好了,此题已经有很多朋友给你解答了。
我想如果,你能针对你的这个分析,想提高一下强度的话,有什么好的建议,提出改进措施(也就是优化问题)我会给你加分的!
发表于 2003-10-20 21:53:26 | 只看该作者
游客,本帖隐藏的内容需要积分高于 1 才可浏览,您当前积分为 0
发表于 2004-5-14 11:51:19 | 只看该作者
m,s ,n , ton
30
发表于 2004-5-15 10:56:06 | 只看该作者
4、我胡乱使用了一种单元SOLID92,因为没有概念,天知道是个什么东西!(该使劲打PP)
最好用SOLID45----^-^我也是菜菜
GMT+8, 2025-4-28 06:18 , Processed in 0.027976 second(s), 11 queries , Gzip On, Redis On.
