查看: 17147|回复: 3
【求助】 [求助]如何adams载荷文件输入ansys61中动态分析
发表于 2003-10-23 10:10:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问,我需要再adams中生成一个载荷文件,并且要把这个载荷文件输入到ansys6.1中的模型,作分析,具体的操作过程,我不熟悉,希望在这方面的高手帮忙
发表于 2003-11-3 08:30:04 | 只看该作者
ansys61中solution下有adams的接口模块,将adams中形成的.lod文件载入即可
发表于 2003-11-8 18:59:02 | 只看该作者
Once you have exported the load file, you can perform a stress analysis for Link3 in ANSYS using the command input shown below.RESUME,adamsout,db      ! Resume model
/FILNAM,adamsin         ! Change jobname
/TITLE,Import loads from ADAMS     ! Change title
WSPRINGS                ! Create weak springs
! Enter Solution and solve all load steps
/SOLU
/INPUT,loads,lod        ! Read in 5 load steps written by ADAMS
*DO,i,1,5               ! Use a do loop to solve each load step
  LSREAD,i              ! Read in loadstep
  IRLF,1                 ! Activate inertia relief
  SOLVE                 ! Solve current load step
*ENDDO
/POST1                  ! Enter the general postprocesser
! Write deformation and equivalent stress to graphics file
/VIEW,1,1,1,1
/AUTO,1
EPLOT
/TYPE,1,4
/SHOW,
EPLOT
*DO,i,1,5
  SET,i
 &nbspLNSOL,u,sum
 &nbspLNSOL,s,eqv
*ENDDO
/SHOW,term
FINISH
/EXIT,nosave
发表于 2003-11-8 19:00:17 | 只看该作者
但愿对你有一定的启发,呵呵!你如果成功了,不要忘记告诉大家你的操作!
GMT+8, 2025-4-10 23:32 , Processed in 0.026302 second(s), 13 queries , Gzip On, Redis On.
