来自Jeffrey Lee那里
! These options control text not subject to other options
! 这些选项控制与其他选项无关的文本
!下面3项控制工程图文本字高、字体笔宽和字体宽度因子
drawing_text_height 2.200000
text_thickness 0.000000
text_width_factor 0.80000
! These options control views and their annotations
!下面这些选项控制视图和它们的注释
broken_view_offset 1.000000
create_area_unfold_segmented YES
def_view_text_height 2.500000
def_view_text_thickness 0.000000
detail_circle_line_style SOLIDFONT
detail_view_circle ON
half_view_line SOLID
!half_view_line SYMMETRY
projection_type THIRD_ANGLE
!set 1st angle projection,set projection_type FIRST_ANGLE
show_total_unfold_seam YES
!==Set the scale format===
!Scale format:SCALE x.000 please set
!下面这项设置VIEW的比例分母:
!view_scale_denominator 0
!view_scale_format decimal
!The following is scale format SCALE X:Y
view_note STD_ANSI
!Also can set View_Note:STD_ISO,STD_DIN,STD_JIS
view_scale_denominator 10
view_scale_format RATIO_COLON
!scale format SCALE x/y should set view_scale_format FRCTIONAL
! These options control cross sections and their arrows
! 这些选项控制横截面和它们的箭头。
crossec_arrow_length 2.500000
crossec_arrow_style TAIL_ONLINE
!DIN STD:crossec_arrow_style HEAD_ONLINE
crossec_arrow_width 1.000000
crossec_text_place ABOVE_LINE
!Corsse_text_place also can set to:AFTER_HEAD,ABOVE_TAIL
cutting_line STD_ANSI
!cutting_line can set those value:STD_ANSI,STD_ISO,STD_JIS_ALTERNATE,STD_DIN,STD_JIS
cutting_line_adapt NO
cutting_line_segment 2.000000
draw_cosms_in_area_xsec NO
!remove_cosms_from_xsecs ALL
remove_cosms_from_xsecs TOTAL
! These options control solids shown in views
! 这些选项控制在视图中显示的实体
datum_point_size 0.312500
datum_point_shape CROSS
hlr_for_pipe_solid_cl NO
hlr_for_threads Yes
location_radius DEFAULT(2.)
mesh_surface_lines ON
!设定螺纹标准:
!thread_standard Can Set:STD_ANSI,STD_ISO,STD_ISO_IMP_ASSY,STD_ISO_IMP
thread_standard STD_ISO_IMP_ASSY
hidden_tangent_edges DEFAULT
ref_des_display NO
weld_solid_xsec NO
! These options control dimensions
! 这些选项控制尺寸
allow_3d_dimensions YES
angdim_text_orientation HORIZONTAL
!angdim_text_orientation Also can set to ARALLEL_ABOVE,HORIZONTAL
associative_dimensioning YES
blank_zero_tolerance NO
chamfer_45deg_leader_style STD_ASME_ANSI
!chamfer_45deg_leader_style Also can set to:STD_JIS,STD_DIN,STD_ASME_ANSI
clip_dimensions YES
!clip_dim_arrow_style DOUBLE_ARROW
clip_dim_arrow_style NONE
default_dim_elbows YES
dim_fraction_format STD
!dim_fraction_format DEFAULT
dim_leader_length 4.500000
dim_text_gap 0.500000
draft_scale 1.000000
draw_ang_units ANG_DEG
draw_ang_unit_trail_zeros yes
!以下设定标注双重尺寸(公及英制同时标)
dual_digits_diff -1
!DIN set :dual_digits_diff 1
dual_dimension_brackets YES
dual_dimensioning NO
dual_secondary_units INCH
iso_ordinate_delta Yes
lead_trail_zeros BOTH
!上面一项是设DIM两头成不截0,若截尾0,设为STD_METRIC,Also can set: STD_DEFAULT
lead_trail_zeros_scope DIMS
!设定坐标法标尺寸的标准(用ANSI比较好,不会有你不想要的箭头)和尺寸文字方向:
ord_dim_standard STD_ANSI
!ord_dim_standard Also can set to:STD_ANSI ,STD_DIN,STD_ISO
orddim_text_orientation PARALLEL
parallel_dim_placement ABOVE
!下面这项设定缩水率显示方式为:百分比
shrinkage_value_display PERCENT_SHRINK
!设定尺寸文字方向:
text_orientation PARALLEL_DIAM_HORIZ
!text_orientation Also can set to ARALLEL,PARALLEL_DIAM_HORIZ,Horizontal
tol_display YES
tol_text_height_factor STANDARD
tol_text_width_factor STANDARD
!tol_text_height_factor 0.500000
!tol_text_width_factor 0.750000
use_major_units NO
witness_line_delta 1.500000
witness_line_offset 1.000000
! These options control text and line fonts
! 这些选项控制控制文本和线型
default_font FONT
aux_font 1 filled
!the following is set other and chinese fonts style:
aux_font 2 leroy
aux_font 3 cal_alf
aux_font 4 cal_grek
aux_font 5 chfntk
aux_font 6 chfntf
aux_font 7 chfnth
! These options control leaders
! 这些选项控制方向指引
draw_arrow_length 2.500000
draw_arrow_style FILLED
dim_dot_box_style FILLED
!dim_dot_box_style DEFAULT
draw_arrow_width 1.000000
draw_sym_height DEFAULT
draw_sym_width DEFAULT
draw_dot_diameter DEFAULT
leader_elbow_length 5.000000
! These options control axes
! 这些选项控制轴
axis_interior_clipping NO
axis_line_offset 1.500000
circle_axis_offset 1.000000
radial_pattern_axis_circle YES
! These options control geometric tolerancing information
! 这些选项控制几何公差信息
gtol_datums STD_ANSI
!gtol_datums Also can set to:STD_ANSI,STD_DIN,STD_ISO_JIS,STD_ISO
gtol_dim_placement ON_BOTTOM
new_iso_set_datums NO
asme_dtm_on_dia_dim_gtol ON_GTOL
! These options control tables, repeat regions, and BOM balloons
! 这些选项控制表,重复区域和材料清单球标
dash_supp_dims_in_region YES
!def_bom_balloon_leader_sym ARROWHEAD
def_bom_balloon_leader_sym FILLED_DOT
model_digits_in_region NO
show_cbl_term_in_region YES
2d_region_columns_fit_text NO
! These options control layers
! 这些选项控制层
draw_layer_overrides_model YES
ignore_model_layer_status No
! These options control model grids
! 这些选项控制模型网格
model_grid_balloon_size 0.200000
model_grid_neg_prefix -
model_grid_num_dig_display 0
model_grid_offset DEFAULT
! These options control theoretical piping bend intersection
! 这些选项控制理论管道折弯交截
show_pipe_theor_cl_pts BEND_CL
pipe_pt_shape CROSS
pipe_pt_size DEFAULT
! Miscellaneous options
! 杂项选项
decimal_marker COMMA_FOR_METRIC_DUAL
drawing_units MM
line_style_standard STD_ANSI
!line_style_standard Also can set to: STD_DIN,STD_ISO
max_balloon_radius 0.000000
min_balloon_radius 0.000000
node_radius DEFAULT
sym_flip_rotated_text NO
weld_symbol_standard STD_ISO
!weld_symbol_standard STD_ANSI
yes_no_parameter_display TRUE_FALSE
default_pipe_bend_note NO
!_______________________________________________________
! <<<<<<<<<The End>>>>>>>>>>>>
! Updated by Jeffrey Lee,2001,3,28
! Under Pro/Engineer 2000i 1999260 With Cpro. |
