查看: 15937|回复: 1
[求助] 曲面驱动加工方向用GPA函数如何定义?
发表于 2011-12-1 21:13:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
&PROSRF - Reference Vector - Surface Contouring
Synopsis
&PROSRF
Description
Used to specify the drive surface reference vector. The purpose of the reference vector is twofold. First, it indicates the material side of the drive surfaces. Second, it indicates the the projection direction of &REFPT onto the drive surfaces.
Characteristics
Write Only - Three Position Numerical Array - Any Real Number
该贴已经同步到 huangjiuchao的微博
发表于 2011-12-1 21:18:23 | 只看该作者
我用这个函数定义了切削方向和材料方向 但是它每次都是由下往上生成刀路,试了很多改变X,Y,Z数组的值,都不好使,想通过参考点去设置Reference Point - &REFPT 也不好使,请高手指点!!!
GMT+8, 2025-4-22 17:50 , Processed in 0.020451 second(s), 12 queries , Gzip On, Redis On.
