查看: 16723|回复: 2
[讨论] UG二次开发 按类选择对话框
发表于 2011-12-2 12:20:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好,我想实现拉伸功能(先选择线框,然后拉伸),但是按类选择对话框打不开。。代码如下:
int Project_Model_Create_Extrustion(ModelMandrelParameter *p_mandrel_para,tag_t *p_ext_tag)
uf_list_p_t loop_list,features;
char *taper_angle="0.0",*limit[2],limit1[2][30];
double ref_pt[3];
double direction[3] = {0.0,0.0,1.0};
int    i,err;
char cue[] = "选择型材线框";
    char title[] = "按类选择对话框";
    int response, count;
    tag_p_t objects;
char message[200];
sprintf(taper_angle,"%lf",p_mandrel_para->A);
sprintf(limit1[0],"%lf",p_mandrel_para->S);
sprintf(limit1[1],"%lf",p_mandrel_para->E);
limit[0]=limit1[0];limit[1]=limit1[1];
    UF_MODL_create_list(&loop_list);
    if((UF_CALL(UF_UI_select_with_class_dialog(
          cue, title, UF_UI_SEL_SCOPE_WORK_PART,
          NULL, NULL, &response, &count, &objects))) == 0)
  printf("object count = %d\n",count);
         if (response == UF_UI_OK && count > 0)
             for (i=0; i<count; i++)
                 UF_DISP_set_highlight(objects[i], 0);
     UF_MODL_put_list_item(loop_list,objects[i]);
    UF_free(objects);
err=UF_MODL_create_extruded(loop_list, taper_angle, limit,
                          ref_pt, direction, UF_NULLSIGN,&features);
if(err!=0)
  UF_get_fail_message( err,message);
  uc1601(message,1);
  return err;
UF_MODL_ask_list_item(features,0,p_ext_tag);
UF_MODL_delete_list(&features);
return err;
发表于 2012-2-15 09:39:55 | 只看该作者
不懂,帮你顶下,我也好想学
发表于 2012-4-3 21:01:43 | 只看该作者
选择对话框函数代码少了,帮助文档上有例子,可以去看看
GMT+8, 2025-4-22 22:18 , Processed in 0.022877 second(s), 11 queries , Gzip On, Redis On.
