查看: 17874|回复: 2
[分享] 支持Solid Edge ST4--KeyShot 3 升级更新 - 3.0.99 PJ发布(2012-01-31 12:00:19)
发表于 2012-2-8 22:30:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个新的KeyShot 3更新版本已发布. 它修复了以下错误问题:
  • Improved reflections on rough materials
  • Copy and paste of inclination animation type
  • Fixed movie compilation error when rendering out animations in individual chunks
安装包下载更新
完整安装包:
Windows 32 bit:
https://download.keyshot.
com/keyshot_w32_3.0.99.exe
Windows 64 bit: https://download.keyshot.com/keyshot_w64_3.0.99.exe
MAC OS X: https://download.keyshot.com/keyshot_mac64_3.0.99.pkg
升级安装包:
Windows 32 bit:
com/keyshot_w32_3.0.99_update.exe
Windows 64 bit: https://download.keyshot.com/keyshot_w64_3.0.99_update.exe
MAC OS X: https://download.keyshot.com/keyshot_mac64_3.0.99_update.pkg
PJ文件下载:https://115.com/file/be8gl2po#   (仅PJ补丁文件)
如果你是首次试用用户, 请继续阅读.
试用版本限制:
The trial version you are about to install is a fully functional version of KeyShot except for the following:
  • Your saved images will be watermarked.
  • You cannot save any of the scenes you set up.
  • You trial is limited to 15 days per release (e.g. 3.0, 3.1, etc.) per machine
如何开始:
  • After installing KeyShot, the software will start automatically.
  • Please select "Try".
  • Fill in the information, and select "Activate".
  • KeyShot will connect to the server and automatically receive a license. Skip steps 5-7.
  • If a server connection can't be established, save the "license-request.txt" file.
  • Send this file to license@luxion.com.
  • You will receive a license file shortly.
你的首次渲染:
Follow the 6 steps outlined in the quick start guide found under the "Help" menu. We also have a getting started video you can view here.
KeyShot supports the following file types on both Mac and PC:
  • ALIAS 2012 and prior
  • AutoCAD (DWG/DXF)
  • CATIA v5
  • Creo
  • Creo Elements/Pro (Pro/ENGINEER)
  • Inventor 2011 and prior
  • Rhinoceros 4 and prior
  • SketchUp 8 and prior
  • Solid Edge ST4 and prior
  • SOLIDWORKS 2012 and prior
  • NX
  • IGES
  • STEP AP203/214
  • Parasolid
  • OBJ
  • FBX
  • Collada
  • 3DS
  • JT
In addition we provide direct plugins for Creo, Pro/E, Rhino, SolidWorks and SketchUp. Please goto www.keyshot.com/keyshot/pluginsto download and learn more.
PC 机配置:
  • Windows XP 32/64 bit
  • Windows Vista 32/64 bit
  • Windows 7 32/64 bit
  • AMD or Pentium 4 processor or better
Mac 机配置:
  • INTEL-based Mac, Core2Duo processor or higher
  • Mac OS X 10.5 or later
  • 3 button mouse, incl. Magic Mouse plus MagicPrefs
一般系统配置:
  • Minimum 1 GB of RAM
  • Minimum 500MB hard disk space
  • 3 button mouse
  • Monitor resolution of 1024 X 768 or greater
  • Any graphics card (nothing special required)
  • Internet connection for product activation
Enjoy!
Your KeyShot Team
For your records, here is a copy of the information you submitted to us...
发表于 2012-2-9 07:35:03 | 只看该作者
3.099很多人反映 不稳定啊!
发表于 2012-2-9 18:20:31 | 只看该作者
看来还是先继续用3.0.82了。
GMT+8, 2025-4-19 21:56 , Processed in 0.031441 second(s), 13 queries , Gzip On, Redis On.
