查看: 16095|回复: 0
[求助] adams仿真错误求助
发表于 2012-3-14 17:14:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
机构不动报错,请各位大大帮忙看看
WARNING:    After 50 iterations of the calculations for the initial conditions, the
   mechanism has been assembled with a maximum-magnitude error of 4.44015E-10
   which does not satisfy the specified tolerance of 1.0E-10 .
WARNING:    After 25 iterations, the accelerations and constraint forces have
   not been resolved to within the specified tolerance of 1.0E-04 .
WARNING:    The symbolic refactorization failed.  The matrix is structurally singular
   at time = 5.0E-03.
这个是什么问题啊
GMT+8, 2025-4-20 06:33 , Processed in 0.021046 second(s), 14 queries , Gzip On, Redis On.
