查看: 21296|回复: 21
【原创】POST系列讨论之一——生成标准的格式
发表于 2003-11-5 21:19:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
首先可以利用ductpost1400或者1405产生标准的格式。
其所能产生的标准格式参照c:\dcam\config\ductpost里面的OPT文件的名称。一共50种。
发表于 2003-11-5 21:22:37 | 只看该作者
如何产生标准的OPT文件呢?
首先要确定控制器的类型。
在开始\程序\附件中进入DOS状态。
按照动画处理(依fanuc15m)为例
发表于 2003-11-5 21:24:19 | 只看该作者
生成的opt文件内容如下
发表于 2003-11-5 21:25:07 | 只看该作者
machine fanuc15m
   define word /
   address letter = "/"
   end define
   define word N
    address letter = "N"
   end define
   define word G1
    address letter = "G"
   end define
   define word G2
   end define
   define word G3
   end define
   define word G4
   end define
   define word G5
   end define
   define word G6
   end define
   define word G7
   end define
   define word X
    address letter = "X"
   end define
   define word Y
    address letter = "Y"
   end define
   define word Z
    address letter = "Z"
   end define
   define word I
    address letter = "I"
   end define
   define word J
    address letter = "J"
   end define
   define word K
    address letter = "K"
   end define
   define word R
    address letter = "R"
   end define
   define word R2
   end define
   define word Q
    address letter = "Q"
   end define
   define word A
    address letter = "A"
   end define
   define word B
    address letter = "B"
   end define
   define word C
    address letter = "C"
   end define
   define word U
    address letter = "U"
   end define
   define word V
    address letter = "V"
   end define
   define word W
    address letter = "W"
   end define
   define word Z2
   end define
   define word F
    address letter = "F"
   end define
   define word S
    address letter = "S"
   end define
   define word T
    address letter = "T"
   end define
   define word M1
    address letter = "M"
   end define
   define word M2
   end define
   define word L
    address letter = "L"
   end define
   define word P
    address letter = ""
   end define
   define word D
    address letter = "D"
   end define
   define word E
    address letter = "E"
   end define
   define word H
    address letter = "H"
   end define
   define word O
    address letter = "O"
   end define
   define word MS
    address letter = "("
   end define
   define word EM
    address letter = ")"
   end define
   define word OP
   end define
   define word ID
    address letter = ":"
   end define
   define word Q1
   end define
   define word null
    address letter = ""
   end define
   define format ( / G6 S T M1 M2 L P D E H O )   定义格式(/ G6 S T M1 M2 L P D E H O)
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    leading zeros              = false
    trailing zeros             = true
    decimal point              = false
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( N )
    address width              =   1
    field width                =   4
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( G1 G2 G3 G4 G5 G7 )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = none
    not permanent
    modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( X Y Z R B C )
    address width              =   1
    field width                =   8
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = if negative
    not permanent
    modal
   metric formats
    trailing zeros             = false
    decimal point              = true
    decimal places             =   3
   imperial formats
    decimal places             =   4
   end define
   define format ( I J K )
    address width              =   1
    field width                =   8
    exponent width             =   0
    scale factor               =  -1
    tape position              =   1
    print position             =   1
    sign                       = if negative
    not permanent
    not modal
   metric formats
    decimal places             =   3
   imperial formats
    decimal places             =   4
   end define
   define format ( R2 Z2 Q1 )
    address width              =   1
    field width                =   8
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = if negative
    not permanent
    not modal
   metric formats
    decimal places             =   3
   imperial formats
    decimal places             =   4
   end define
   define format ( Q A U V W )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = if negative
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( F )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = if negative
    not permanent
    modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( MS EM OP )
    address width              =   1
    field width                =   0
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( ID )
    address width              =   1
    field width                =   4
    exponent width             =   0
    scale factor               =   1
    tape position              =   1
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    leading zeros              = true
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( null )
    address width              =   0
    field width                =   0
    exponent width             =   0
    scale factor               =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
# linked words
   define format ( MS )
     link to EM
   end define
    word order = (    OP   N    G1   G2   G3   G4   G5   )
    word order = ( +  G6   G7   X    Y    Z    B    C    )
    word order = ( +  I    J    K    R    D    S    T    )
    word order = ( +  H    M1   M2   MS   msg  EM   Q    )
    word order = ( +  Q1   Z2   R2   ID   F    )
  define keys
    blocknumber                       = N
    preparatory function              = G1
    aux function                      = M1
    x feedrate                        not used
    y feedrate                        not used
    z feedrate                        not used
    circle angle                      not used
    x coordinate                      = X
    y coordinate                      = Y
    z coordinate                      = Z
    key i                             = I
    key j                             = J
    key k                             = K
    feedrate                          = F
    feedrate per revolution           = F
    spindle                           = S
    tool number                       = T
    cycle dwell                       = Q
    dwell                             = X
    tool length                       = H
    tool radius                       = D
    drill peck depth                  = Q1
    drill hole depth                  = Z2
    clearplane                        = R2
    message start                     = MS
    message end                       = EM
    opskip                            = OP
    radius                            = R
    program id                        = ID
    azimuth axis                      = B
    elevation axis                    = C
    3rd rotation axis                 = null
    leader                            not used
    x vector                          not used
    y vector                          not used
    z vector                          not used
  end define
  define codes
    rapid                             =  G1    0
    linear                            =  G1    1
    circle cw                         =  G1    2
    circle ccw                        =  G1    3
    dwell                             =  G6    4
    xy plane                          =  G3   17
    zy plane                          =  G3   19
    xz plane                          =  G3   18
    compensation off                  =  G2   40
    compensation on left              =  G2   41
    compensation on right             =  G2   42
    imperial data                     =  G4   20
    metric data                       =  G4   21
    absolute data                     =  G5   90
    incremental data                  =  G5   91
    from                              =  G3   54
    feedrate per minute               not used
    feedrate per revolution           not used
    spindle rpm                       not used
    constant surface speed            not used
    drill                             =  G4   81
    break chip                        =  G4   82
    deep drill                        =  G4   83
    tap                               =  G4   84
    bore 1                            =  G4   85
    bore 2                            =  G4   86
    bore 3                            =  G4   87
    bore 4                            =  G4   88
    bore 5                            =  G4   89
    end of drill                      =  G4   80
    macro start                       not used
    macro end                         not used
    macro call                        not used
    cycle retract                     =  G6   99
    tool length offset                =  G6   43
    spline                            not used
    stop                              =  M1    0
    opt stop                          =  M1    1
    spindle on cw                     =  M1    3
    spindle on cc                     =  M1    4
    spindle off                       =  M1    5
    spin coolant on cw                =  M1   13
    spin coolant on ccw               =  M1   14
    spin coolant off                  =  M1    5
    change tool                       =  M1    6
    coolant on mist                   =  M2    7
    coolant on                        =  M2    8
    coolant on flood                  =  M2    8
    coolant off                       =  M2    9
    clamp on                          not used
    clamp off                         not used
    end of tape                       =  M1    2
    end of prog                       =  M1   30
    gear range 1                      not used
    gear range 2                      not used
    gear range 3                      not used
    constant contour speed            not used
    constant contour speed 2          not used
    word drill                        not used
    word break chip                   not used
    word deep                         not used
    word tap                          not used
    word bore 1                       not used
    word bore 2                       not used
    word bore 3                       not used
    word bore 4                       not used
    word bore 5                       not used
  end define
  print header               = "Delcam Postprocessor"
  machine name               = "Fanuc11m         version 1.1"
  point                      = "."
  zero                       = "0"
  tape headers               =     0
  integer   6                =     2
  integer   7                =     1
  integer  10                =     2
  integer  11                =     1
  integer  12                =     1
  tool reset coordinates     =     2
  cycle output               =     1
  integer  20                =     1
  block start                =    10
  block increment            =    10
  split move                 =     0
  integer  26                =     1
  program id start           =     1
  integer  34                =     3
  integer  35                =     1
  integer  36                =     1
  integer  37                =     2
  rapid feed code            =     0
  maximum block number       =     0
  maximum tape blocks        =     0
  minimum tape blocks        =     0
  segment type               =     0
  counter start              =     0
  counter increment          =     0
  tape split retract distance  =  -999
  message output             = true
  block order                = false
  tlo output                 = true
  full circle                = true
  incremental centre         = true
  go home output             = false
  use partid                 = true
  use progid                 = true
  spindle x motion           = false
  spindle y motion           = false
  spindle z motion           = true
  spindle w motion           = false
  spindle azimuth rotation   = false
  spindle elevation rotation  = false
  knot vector type           = none
  units                      = input
  coordinates                = absolute
  azimuth axis units         = none
  azimuth axis direction     = none
  elevation axis units       = none
  elevation axis direction   = none
  spline type                = none
  maximum feedrate           =  9999.0000
  minimum feedrate           =     1.0000
  rapid feedrate             =  9999.0000
  maximum tape length        =      .0000
  maximum segment            =      .0000
  diameter                   =     1.0000
  withdrawal amount          =    50.0000
  azimuth axis parameters    = (      0      0      0      1      0      0 )
  azimuth centre             = (      0      0      0 )
  elevation axis parameters  = (      0      0      0      0      1      0 )
  elevation centre           = (      0      0      0 )
  pcs origin                 = (      0      0      0      0      0      0 )
  linear axis limits         = ( -99999 999999 -99999 999999 -99999 999999 )
  rotary axis limits         = ( -99999 999999 -99999 999999    999      1 )
  move safe angles           = (      0      0      0      0 )
  define block tape start
    ID ProgID
    N   ; G2  91    ; G6  28    ; X   0     ; Y   0     ; Z   0
    N   ; compensation off      ; G6  49    ; xy plane  ; G4  80
    N   ; G5  90    ; G1   0    ; Z FromZ
  end define
  define block tape end
    N   ; G6  28    ; G5  91    ; Z   0     ; Z =C
    N   ; H   0     ; G6  49
    N   ; G6  28    ; X   0     ; Y   0     ; X =C      ; Y =C
    N   ; M1  30
  end define
  define block go home preamble
  end define
  define block tool change first
    N   ; OP  ; change tool     ; T ToolNum
    G3  54    ; G5  90    ; T NextTool      ; G3 =C     ; G5 =C     ;
  end define
    N   ; G5  91    ; G6  28    ; Z   0     ; Z =C
    N   ; H   0     ; G6  49
    T NextTool      ; G5  90    ; G3  54    ; G5 =C     ; G3 =C     ;
  end define
  define block tool change clear
  end define
  define block go home z move
  end define
  define block go home xy move
  end define
  define block move from
  end define
  define block move circle
    OP  ; N   ; G1  ; G2  ; G3  ; X   ; Y   ; Z   ; R =C      ; F   ; D   ;
    B   ; C
  end define
  define block move linear
  end define
  define block move rapid
    N   ; G1  ; G2  ; G3  ; G5  ; G6  ; X   ; Y   ; Z   ; T   ; H   ; S   ;
    M1  ; M2  ; M1  ; M2
  end define
  define block move cycle
    N   ; G4  ; G6  ; X   ; Y   ; Z2  ; R2  ; Q   ; Q1  ; F   ; M2
  end define
  define block move tap
    N   ; G6  ; G4  ; X   ; Y   ; Z2  ; R2  ; F   ; M1  ; M2
  end define
  define block tape segment
  end define
  define block tape split start
    ID ProgID
  end define
  define block tape split end
    N   ; G1  28    ; G6  91    ; Z   0     ; Z =C
    N   ; H   0     ; G6  49
    N   ; M1  30
  end define
  define block cycle start
    N   ; S   ; M1
    N   ; G3  ; G5  ; M2
    F =C      ; G4 =C     ; Z2  ; R2  ; Q   ; Q1  ; G6  ;
  end define
  define block cycle end
    G4  80
  end define
  define block tape split move
  end define
  define block move spline
  end define
end
发表于 2003-11-5 21:30:44 | 只看该作者
为了解读这个OPT文件的含义。我们先从DUCTPOST在线帮助文件入手。
从开始\程序\dcam\ductpost
发表于 2003-11-5 21:34:25 | 只看该作者
进入帮助文件以后我们发现并不是所有的连接都能够用,有的点击以后仍然是空白,这是可以点击相应的图标点击右键\属性,查看源程序的编号。可以到PM的安装目录下面找出调不出来的文件
发表于 2003-11-5 21:35:34 | 只看该作者
看到属性后按照指示可以找到该文件
发表于 2003-11-6 07:28:38 | 只看该作者
兄弟,作了代理就是不一样。。。::y::y::y::y::y
发表于 2003-11-6 10:13:38 | 只看该作者
自己瞎摸索。现在不出差就摸它
现在活没有以前作的多了耶:~)
发表于 2004-3-21 15:55:27 | 只看该作者
laopu_sd wrote:
  自己瞎摸索。现在不出差就摸它
  现在活没有以前作的多了耶:~)
请问师兄:
怎么把CMD里DUCTPOST -W显示出来的东西,整成文字格式的?
你的AVI我看不了
自己摸出来了ductpost  -w  控制器名字] >  文件名字. opt
GMT+8, 2025-4-24 12:43 , Processed in 0.032674 second(s), 11 queries , Gzip On, Redis On.
