查看: 16369|回复: 6
【公告】MPI4.1发布第二个补丁了
发表于 2003-11-7 11:13:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
补丁也有40M快赶上整个安装程序大了。
发表于 2003-11-9 07:47:37 | 只看该作者
好期待....
发表于 2003-11-11 23:06:38 | 只看该作者
thanks i want
发表于 2004-1-6 22:04:26 | 只看该作者
MPI4.0的补丁哪里有下载啊
发表于 2004-1-7 09:15:59 | 只看该作者
第四个补丁都出来了。
发表于 2004-1-13 11:16:45 | 只看该作者
Release Notes: MPI 4.1 Revision 4
MPI 4.1 Revision 4 includes fixes/enhancements to the
following areas (along with fixes/enhancements made in
MPI 4.1 Revision 3, MPI 4.1 Revision 2 &
MPI 4.1 Revision 1):
* User interface related bug fixes
___________________________________________________________
User interface related fixes
* When attempting to delete a study from the Project View,
  the active study (i.e. the study that is opened and
  active) is deleted, instead of the study selected to be
  deleted. This problem is now fixed.
Release Notes: MPI 4.1 Revision 3
MPI 4.1 Revision 3 includes fixes/enhancements to the
MPI 4.1 Revision 2 & MPI 4.1 Revision 1):
* Meshing related bug fixes
* Various solvers related bug fixes
* Material database related changes
* Miscellaneous fixes
* When you switch from one to study window to another, the
  active study in the Project View pane changes
  accordingly.
* Problem with displaying identical 1D elements is now
  fixed.
* Duplicated parts can loose information required for a
  warp analysis. This problem is now fixed.
* Creating a new plot with particular inputs may not work.
* Problem with querying results in cylindrical coordinate
  system is now fixed.
* Problem with updating 3D results with a clipping plane.
* Cutting plane does not work with the Zone result. This
* XY plot origin changes when using default options. This
* The 'Flow rate, beams' MPI/3D Flow result does not show
  a legend. This problem is now fixed.
* VTK error received when displaying the stress tensor from
  microchip analysis. This problem is now fixed.
Meshing related fixes
* Mesh Diagnostics displays the correct calculates correct
  shape factor and thickness for cross-sectional shapes.
* Fixed problem with reflecting a tetrahedral mesh.
Various solver related fixes
* MPI/Fiber analysis speed has improved by 10% to 20% for
  midplane/fusion meshes.
* MPI/3D Flow analysis speed has improved by 10% to 40%.
* Automatic injection time gives unrealistic long fill time
  in some cases. This problem is now fixed.
* Fixed problem with Fusion fill analysis taking too long.
* Problem with Flow analysis hanging after switchover is
  now fixed.
* Problem with Molding Window returning wrong results is
  now fixed.
* Removed the fiber orientation convergence tolerance
  input that caused error 99250. This input is now
  obsolete.
* Fixed a problem with shortshot at gate in MPI/3D Flow.
* MPI/3D Flow analysis with networked runner system returns
  error 220128. This problem is now fixed.
* MPI/3D Flow analysis returns error 220038. This problem
  is now fixed.
* Fixed problem with flow rate on beam elements with
  occurrence number in MPI/3D Flow.
* Fixed problem with assigning flux boundary condition on
  part inserts. Previously, this caused analysis to fail.
* Fixed a problem with MPI/3D Flow analysis when specifying
  a boundary temperature on a part insert. Previously, the
  analysis returned a message about an unrealistic minimum
  mold temperature.
* MPI/3D Flow now displays a message with the correct CPU
  time used on Windows platforms. Previously, the message
  displayed the actual elapsed analysis time.
* A grill part with hole, offset and a shortshot causes
  Warp to crash. This problem is now fixed.
* Fillcalc materials are missing Material IDs. This problem
  is now fixed.
Miscellaneous fixes
* The calc vbs file (API) is now installed with the
  product.
Release Notes: MPI 4.1 Revision 2
MPI 4.1 Revision 2 includes fixes/enhancements to the
* Issue resolved where modeling a runner system (or any
  curve) after the part had already been meshed, and then
  meshing the new curve entities caused the part to be
  remeshed, even if the "Remesh already meshed parts of
  the model" option on the Generate Mesh dialog was off.
Release Notes: MPI 4.1 Revision 1
MPI 4.1 Revision 1 includes fixes/enhancements to the
following areas:
* User Interface related bug fixes
* Modeling related bug fixes
* Various Solvers related bug fixes
* Material Database related changes
User Interface related fixes
* When legacy Moldflow materials (*.asc) are imported on
  UNIX platforms, supplemental data might not show up in
  red color in the user interface. This issue is now
  resolved.
* Miscellaneous issues in result visualization are now
  fixed.
Modeling related fixes
* Speed improvements have been made in various modeling
  functions, such as creating regions from a boundary.
* Copying beam elements left behind unnecessary holes in
  element numbers, which might cause analysis problems.
  This issue is now resolved.
* Problems with importing some node definitions with spaces
  from Nastran models is now resolved.
* The Bounding Box is now calculated much faster.
* When 3D BDF mesh files are imported and remeshed,
  global edge length was not calculated correctly. This
* Meshing now handles overmolded components correctly.
 &nbspreviously, the mesher used to assign tetrahedron
  properties to overmolded components.
* MPI/Fiber analysis speed has improved by 15% to 40%.
* MPI/Flow analysis speed has improved by 5% for unfilled
  materials, and 20% to 45% for filled materials.
* MPI/Flow now outputs a result summary of the packing
  phase and sink mark depth results, in case of short
  shots.
* MPI/3D Flow analysis calculated results incorrectly if
  'Machine pressure limit' was specified as 'Maximum
  machine injection pressure' and 'Pack/holding control'
  was specified as 'Hydraulic pressure vs time'. This
* MPI/3D Flow analysis on IBM and HP Itanium platforms
  had rounding off differences in Tensile modulus and
 &nbspoisson's ratio results. This issue is now resolved.
* MPI/3D Flow analysis now treats flow front activated
  valve gates correctly.
* MPI/MuCell analysis now outputs the 'Linear thermal
  expansion coefficient' result correctly.
* MPI/Thermoset Flow on midplane/fusion models now allows
  for setting different tool and runner temperatures.
* MPI/Cool analysis would not run an injection compression
  analysis. This issue is now resolved.
* MPI/Cool analysis would stop with an error if the model
  contained overflow wells. This issue is now resolved.
* MPI/Cool analysis using mesh aggregation would not
  converge for some models. This issue is now resolved.
* MPI/Cool analysis would not output the "Time to Freeze,
  part" result on unfilled edges. This issue is now
  resolved.
* MPI/Stress 3D analysis would not converge on some models
  for Microchip Encapsulation process with paddle shift.
* MPI/3D Warp analysis convergence has been improved.
* Detailed Release Notes for the material database are
  separately available on the Moldflow Community Center.
 &nbsplease look for this information under the
  Get Files/Documentation section.
Miscellaneous fixes
* The Application Programming Interface (API) now provides
  access to various mesh diagnostics. Locale is now being
  set to "en-us" for all scripts being recorded so that
  commas are treated correctly in command line arguments
  (for example, they would be treated in German locales).
  Also, it is now possible to set the unit system and set
  units for XY plots.
* When recovering models from auto-saved files, titles of
  models may not be correct. This issue is now resolved.
* License troubleshooting wizard now works correctly on
  all Windows platforms.
发表于 2004-1-29 15:13:53 | 只看该作者
給你放煙火!!
GMT+8, 2025-7-8 16:03 , Processed in 0.026422 second(s), 12 queries , Gzip On, Redis On.
