查看: 15855|回复: 4
【灌水】天冷坛更冷
 关闭 [复制链接]
发表于 2003-11-9 21:14:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近怎么了?
发表于 2003-11-10 17:33:42 | 只看该作者
是呀!难道大家都很忙。还是觉得ideas没前途了
发表于 2003-11-10 20:53:30 | 只看该作者
  :I:I:I   would be change...
发表于 2004-6-29 19:14:09 | 只看该作者
看来是ideas没有前途了
发表于 2004-6-30 13:11:58 | 只看该作者
yes ,I have the same ideas ,I have been used the software for 4 months ,but I find sometimes it is difficult to use ,eg if you want to use the existing lines or curves from one part to a new one in an assembly ,there are without relativity ,if you want  modification the new part can't update in the same time ,I realize the  process are complexes in drafting you there are have't automatic to align   the aux view with the parent view , the software include much more   functions than other 3D design software ,but in fact  it must enhance and develop such as pro_engineer .what do you think ?
GMT+8, 2025-4-22 13:13 , Processed in 0.034222 second(s), 11 queries , Gzip On, Redis On.
