查看: 15537|回复: 4
【讨论】【求助】请教!
发表于 2003-11-12 16:46:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这种效果怎么做出来的?——动态拉伸::y::y
发表于 2003-11-12 19:48:14 | 只看该作者
在UGII_ENV.DAT里加上如下内容:
UGII_NEW_EXTRUDE=613
  UGII_TRIM_AND_EXTEND=613
  UGII_CORNER_DART_DEMO=613
  UGII_VSWEEP_DEMO=613
# ugii_env_default: Standard template used to set up $UGII_ROOT_DIR/ugii_env.dat
# Copyright (c) 1991-2003 Unigraphics Solutions, Incorporated
#                         Unpublished - All rights reserved
#  The following list is the master list of environment variables for
#  Windows NT systems.  The variables are read from the file "ugii_env.dat"
#  when unigraphics processes start up.  This list is meant to be
#  a master version of the UGII_ENV file.
发表于 2003-11-12 20:04:58 | 只看该作者
然后按下列步骤可以做到:
Insert-From Feature-Extrude Dialog
发表于 2003-11-12 21:29:56 | 只看该作者
楼上的贴子,我喜欢
发表于 2003-11-13 08:52:32 | 只看该作者
谢谢!::g::g
GMT+8, 2025-4-28 17:53 , Processed in 0.023498 second(s), 11 queries , Gzip On, Redis On.
