查看: 15852|回复: 1
【求助】Create a fillet,but not trim the circle!
发表于 2002-8-12 23:40:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Create a fillet that is tangent between the two circles. But the fillet will not trim the circles as you create it. How to make it! How to set it! Thank you for tell me the answer!
发表于 2002-8-13 09:55:19 | 只看该作者
To solve the problem,you should select the Trim First Curve and Trim  Second Curve
GMT+8, 2025-4-21 01:17 , Processed in 0.026609 second(s), 11 queries , Gzip On, Redis On.
