(defun c:mjd ()
" F1 s! ^. @& l7 V+ N2 U% j0 j3 G (prompt "请输入要求非标面积的层名: ")* W* B4 [$ h4 i, Q
(setq aly (getstring))5 v1 f3 b7 w4 Y# y
(command "layer" "s" "0" "f" "*" "t" aly "")# i+ d/ z. {& N f, M! G
(setq ena (ssget "x" '((8 . "025"))) n (sslength ena) i 0)' x' a( [4 E) o
(setvar "clayer" "0")(setvar "cmdecho" 0)
1 v/ y6 v. C! n, Z (while (setq ena (entsel "选择图形: "))
- x3 ^, g0 _- q9 j1 u7 S (setq en (car ena) ee (entget en) ee (entget en) )
/ n6 J8 `* e4 p. v# P/ O/ T8 e" P% ` (command "list" en "")
: F9 u" D5 l+ m4 P9 G% c (setq a (getvar "area") aa (/ a 1000000.0) aa (rtos aa 2 4)). K, Y9 r) H, v. o1 p1 G& w
(setq p1 (getpoint "/n文字位置: ")): H, |# Y, }' U0 d3 r3 |; W8 p
(command "text" p1 "200" "0" aa)
; e& L% ?# {5 n2 l {" H: b )
; J; V. H# J6 a4 I; |7 j (setvar "cmdecho" 1)
) U$ O2 ?! A6 X+ l/ x)
- A0 N( n0 _- m6 A8 `(defun c:mjw ()
" ^4 O/ V7 t8 k' V$ L3 B (prompt "请输入要求非标面积的层名: ")' w8 t1 ?6 s6 ]
(setq aly (getstring))/ ~. [, X( b. X3 v' q
(command "layer" "s" "0" "f" "*" "t" aly "")8 H" X9 p9 K7 k7 R0 A" [
(prompt "选择要标面积的图形: ")
6 z% _7 T3 V% ?+ l6 Y) f- |# P, o (while (setq ena (ssget ) )! k& ` B( s. n' [* S9 Q" [% ~
(if (/= ena nil)(setq n (sslength ena) i 0)(setq n 0))
* e3 k6 g' I) E0 Y9 u2 j+ T (repeat n. n3 Y8 s4 z" f; v _* D- E0 `
(setvar "clayer" "0")(setvar "cmdecho" 0), _ x- X* L0 h
(setq en (ssname ena i) ee (entget en) lla (cdr (assoc 8 ee)) i (1+ i))0 B" e& m6 f. x% S! g# k- z y1 \, N
& I& G& |( a! h m: w1 x (command "change" en """p" "la" "0" ""): t/ a; x$ C- F4 i& _) L6 L. d
(setq a (getvar "area") aa (/ a 1000000.0) aa (rtos aa 2 4))4 d1 h) P; t7 C& j9 ~' ~3 R. ~
( j. y( e" _% e. b9 y (command "text" p1 "200" "0" aa)
4 V/ D! b( H$ T6 c! T- H (command "change" en """p" "la" lla "")
% s; M6 R; `! t )# _& `. E J2 [: J+ j) b& X
)& J9 o, N8 u- n$ f- k+ |! x2 c' {
# s/ {+ X; T3 k! \& q. o8 Y) |
