查看: 16881|回复: 0
[分享] Solid Edge ST4 MP6 Update & crack (by SSQ)
发表于 2012-6-12 23:03:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
115.com
https://115.com/file/an2gmquc#SE-ST4-MP6-32bit-Update-SSQ.rar
https://115.com/file/dp4z7p0f#SE-ST4-MP6-64bit-Update-SSQ.rar
RapidShare
h-ttps://www.rapidshare.com/files/2166336005/SE_ST4_MP6_32bit_Update_SSQ.rar
h-ttps://www.rapidshare.com/files/50266967/SE_ST4_MP6_64bit_Update_SSQ.rar
List of fixed bugs
This Maintenance Pack addresses the following PRs:
===Assembly===
PR 1874517: Solid Edge hangs on “update all”
PR 1891465: One of three base planes is missed in ASM file
PR 6676148: 'Cannot be saved' message when saving a second time
PR 6698274: Incorrect orientation of user defined coordinate system
PR 6702320: Normal Directions not shown in Simulation with Edit Region Direction
PR 1882889:  Message "Network error has been detected..." appears after calling GetReadOnly
PR 1857457: Incorrect configuration listed after returning from IPA
PR 2186316: Auto restore is not working when using backups
PR 6711261: Corruption of assembly file when saving in ST4 due to missing master parts
PR 1828742: Solid Edge Frame Design / Routing API
PR 1890321: Piping relationships conflict when the fitting is flipped
PR 2188371: Freezing during save after RMB in graphic window
PR 6704784: Connectors break when a study is copied
PR 6707111: Crashing when updating all links
===Draft===
Paul - PR 1877712: Dimension values are changed after deleting break lines on dft views
PR 1878646: Special character is lost by parts list properties dialog
PR 1890261: Section View disappears after update
PR 1894625: Unable to read a "Write protected AutoCAD configuration file
PR 2190276: The position text strings move down subtly when opening a V15 draft file is opened with ST4
PR 6694954: Able to delete in use Style and System Styles via automation
PR 1862979: draft views of top level and sub-assembly with assembly features
PR 2190287: The position of a cutting plane caption will move upward when the file is opened
PR 6689785: SE crashes when opening AutoCAD file
PR 1892292: performance impact when dragging and dropping a block within a block
PR 1894479: Captions of drawing view donґt exported to AutoCAD paper space
PR 1897666: Cyrillic text is not displaying correctly in the Table/Titles Tab
PR 1898642: Parts list is not out-of-date after adding a item number balloon
PR 6689394: Property text relocates itself when its value is changed
PR 6690768: Property Text "Width" is not retained
PR 1872546: Font changes although font is set in text style
PR 1894504: Problems mapping Tahoma font to AutoCAD
PR 1894668: Translation from SE to AutoCAD Excel objects is incorrect
PR 1897371: Connectors are incorrect when opening V20 drawing files
PR 1898495: Invisible dimensions are exported visible
PR 1823728: Line type scale not applied on Translation to AutoCAD
PR 2196671: View disappears from display when editing its boundaries
PR 6720152: Independent detail view profile is shown after this workflow
===Part/Profile/Sheet Metal===
PR 2192364: fixes made to prevent frequent random aborts
PR 1890510: Unable to create Swept Surface with section created within the command
PR 6673535: Physical properties of in Lifecycle Viewer do not match CAD
PR 6681198: Rotate face with 2 points vector fails with no error and cannot save after undo
PR 6697991: Not all plots are available in Simulation Results
PR 6553644: activate all crashing after highlighting a groove weld
PR 1866362:  Feature creation and dimension placement is slow
PR 1869002: Unable to select edges of other surfaces when creating Contour curves in ST4
PR 6702794: .NET Framework error when running seINVENTOR.exe
PR 1895060: mirrored ribs are not moving together in ST4 like they did in ST3
            Note: To see the fix, the mirrored ribs will have to be recreated
PR 1899239: Color bar values wrong when plotting 'beam end a/end b min comb stress' data
PR 6446005: Include fails after editing parent edges
===Insight===
PR 1849487: INS Poor Search performance caused by sub-optimal SQL query statements
PR 6571023: Search aborts IE or can hang SE if stopped
PR 1896255: Insight:  Optimized sql query code shows one regression in search
PR 2190773: INS opening managed files causes Solid Edge to crash
PR 1880440: Wrong revision suffix in "Where used file list" for
===Solid Edge Embedded Client===
PR 1893703: EMF is not created when SEEC_Image_Generate_3D is FALSE
PR 6680750: SEEC Administrator Changes to Support Teamcenter 9.1
PR 6705659: integrate 9.1 client to Support Teamcenter 9.1
PR 1894412: Incorrect dataset name for generation of Standard Parts
PR 1894960: Part name property setting not honored when placing a Structural Shape
PR 2167437: Standard Parts exits after placing part
PR 1862616: Extended Standard Parts have an inconstant ItemID - Item name in TC
PR 1896357: Cascading/interdependent LOV not working with SE based Property Category
PR 6702262: Adding "Upload" to the QAT causing memory growth
PR 6717430: Abort due to missing My Documents folder
PR 6657723: ItemID Not Generated Like RAC: USER_EXIT Customization
PR 6718366: SEEC: Tc Exception with Generate JT and AE_dataset_id_usage enabled
GMT+8, 2025-4-30 12:34 , Processed in 0.029549 second(s), 11 queries , Gzip On, Redis On.
