查看: 17795|回复: 6
【求助】有谁知道DVR硬盘录像机机壳的生产厂家
发表于 2003-12-17 14:40:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有知道做类似下图的机壳厂家请告知,谢谢!
发表于 2003-12-17 14:56:39 | 只看该作者
什么材料?
发表于 2003-12-17 16:32:39 | 只看该作者
钣金件, 面板可用塑料.
与家用的VCD,DVD机壳类似.
发表于 2003-12-17 19:26:56 | 只看该作者
现在干嘛大家都做这玩意  A啊,是不是硬盘录象机啊??
发表于 2003-12-18 09:29:19 | 只看该作者
你们做吗,可以告知我所需要的吗?谢谢!
发表于 2003-12-18 15:56:01 | 只看该作者
怎么没有朋友知道吗?想找啊!
发表于 2006-12-11 17:19:45 | 只看该作者
我司有一款430*48MM的刻录机面板(我司自己开的模具),也可提供整套产品以及方案(机器软硬件状态已经可以直接生产大货),不知道贵司是否有兴趣?
      方案采用LSI 8652,机芯采用DVS-200。具体可以看下面的规格介绍。
      此款机器(包括面壳模具,五金模具以及方案)可以打包转让!有兴趣就联系我司!
      本公司有样机可提供测试!!!
HVR 5600 – DVD recorder with HDD and good feature set
Requirements for good DVD recorders are clearly defined: Recording on DVD, integrated HDD, Timeshift
and a lot of interfaces for audio and video. Additionally, it should be easy to operate.
This - and a lot more - offers Xoro HVR 5600. Its 160 GB HDD can store up to 34 hours of movie in highest
quality and more than 200 hours in longplay mode. Timeshift is supported, of course. Additionally,
the device offers progressive scan enabled YPbPr outputs and digital audio interfaces for best picture
and sound quality.
Beyond these features, Xoro HVR 5600 comes with USB and Firewire interface.
Best in class features for a good price.
FEATURES:
- Integrated 160 GB HDD for up to more than 200 hours video
recording
- Records on HDD and DVD+R/RW
- Timeshift enabled
- Integrated video editing, for example to remove commercial breaks
from recorded TV program
- Dubbing from movies from HDD to DVD
- USB interface for easy connection of card readers, USB-Sticks or
external HDD
- Digital recording from Firewire input
- Timer supports VPS system
- Plays DVD Video, DVD+R(W), DVD-R(W), MPEG4, XviD, SVCD,
VCD, CD, Audio-CD, CD-R/RW, JPEG-CD
- Dolby Digital and DTS output (coaxial and optical)
- High quality video output on progressive scan enabled YPbPr
interface
- Integrated Dolby Digital decoder, analog 5.1 CH output
- Supports PAL and NTSC playback
TECHNICAL DATA
General Data
Power inlet 220-240 V AC / 50-60 Hz
Power consumtion < 45 W / < 3 W Standby
TV type PAL/SECAM / NTSC (playback only)
Dimensions 430 x 48 x 349.3 mm (WxHxD)
Net weight about 4.5 kgs
Specification video
Horizontal Resolution 500 TV lines
s/n ratio TBA
Specification audio (Widerstand: 10 kOhm)
Output level 1.8+0.2/-0.8Vrms (1KHz 0dB)
Harmonicdistortion -65dB (JIS-A 1KHz, typical)
Dynamic range < 80 dB (JIS-A 1KHz, typical)
s/n ratio < 90 dB (JIS-A 1KHz, typical)
frequency response 20 Hz - 20 kHz (+/- 3 dB)
Operating conditions
Temperature 5 - 40° C
horizontal platform
Humidity 15 - 75% (non condensing)
Rear side:
Antenna (in and loop through)
Video in (CVBS and S-Video,YCbCr,SCART)
Stereo audio in (RCA)
5.1 CH analog out & stereo out
CVBS ,S-Video,and SCART out
Digital audio out (optical and coaxial)
YPbPr video out, progressive scan enabled)
Front:
Dv-in
USB,
S-VIDEO IN
CVBS in
PACKAGE CONTENT:
- Xoro HVR 5600 DVD-Recorder with HDD
- Remote control
- Batteries for remote control
- SCART cable or AV cable
- User manual (GER, EN, RUS)
COMMERCIAL DATA:
Box dimension (L x H x D): 49.0 x 46.2 x 11.3 cm
Gross weight: 5 kgs
Packaging 1 pcs / 3 pcs in export box
深圳市华然电子有限公司
XORO ELECTRONICS (SHENZHEN) LTD.
深圳市福田区天安数码城创新科技广场二期东1305
Room 1305, 13/F. East,
Tian An Hi-Tech Plaza Phase II,
Tian An Cyberpark,
Futian, Shenzhen, P.R.China
电话(TEL):+86.755.88353121
传真(FAX):+86.755.88353318
邮政编码(POST CODE): 518040
E-MAIL:duan_bingbing@xoro.cn
公司主页(WEB PAGE):
https://www.xoro.de
https://www.xoro.cn
GMT+8, 2025-4-25 09:35 , Processed in 0.025346 second(s), 11 queries , Gzip On, Redis On.
