查看: 16618|回复: 11
Important System Notice - Timeout
发表于 2003-12-18 19:21:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Please note that this page will be updated regularly with new information about the "time-out" issue. As a result, you should visit this page prior to updating your installation.
PTC has recently identified and corrected a software issue that will affect numerous Pro/ENGINEER, Pro/INTRALINK, and Windchill customers worldwide. Specifically, this software issue may cause certain inter-process communications between Pro/ENGINEER and related application modules to "time-out" prematurely on January 10, 2004 and thereafter. This issue, which affects Pro/ENGINEER and related products, does not corrupt data but may impact productive utilization of the software unless addressed before January 10, 2004. Please check below to determine how your implementation is affected.
This isolated software issue can be readily addressed via a small downloadable software patch or by implementing a new maintenance build of the release of the software you have currently deployed.
Please contact PTC's Customer Support organization with questions. Our staff is prepared to support you through this update. Support will be available on this issue to any customer, regardless of maintenance status. We value your business, and we apologize in advance for any inconvenience that we may have introduced.
  ::6::6::6
https://www.ptc.com/go/timeout/
发表于 2003-12-18 21:03:14 | 只看该作者
这么重要的消息怎么没人关注。
Saturday, January 10, 2004 13:37:04 没多少天了。
发表于 2003-12-18 21:29:23 | 只看该作者
到Saturday, January 10, 2004 13:37:04 全部都打不开,软件不能用了是吧
发表于 2003-12-18 21:55:05 | 只看该作者
有可能了
等着PTC的升级包。
发表于 2003-12-18 22:44:42 | 只看该作者
https://www.ptc.com/go/timeout/faq.htm
Will I still be able to run Pro/ENGINEER after January 10, 2004 without this fix?
In general, Pro/ENGINEER will continue to function after January 10, 2004; however various commands and capabilities that utilize inter-process communications will no longer function properly. PTC strongly suggests that all users download and install the appropriate patches.
只是inter-process communications的功能不能用。其他的不受影响,PTC还是强烈建议大家都下载补丁。
发表于 2003-12-18 23:50:59 | 只看该作者
who can translate it into chinese? Thank you!
发表于 2003-12-19 07:33:19 | 只看该作者
就是这个
发表于 2003-12-19 07:37:17 | 只看该作者
好像是针对2001的
发表于 2003-12-19 07:38:27 | 只看该作者
Windows workstations
1.   Exit out of all PTC Applications, and stop all nmsd processes that are still running on the workstation.
*To verify, start ‘Task Manager’, go to ‘Processes’, if a nmsd process is still running, select the process and click #End Process.
2.  Download the new 'nmsd.exe' file for the correct architecture, and place it in a temporary directory.
3.  Replace the nmsd executable located in the '&ltTC_Software_loadpoint>\<machine_type>\nms' directory, and replace it with the nmsd executable downloaded from Step 2.
*Windows location example: d:\ptc\proe\i486_nt\nms
4.  Verify that the new nmsd executable has been placed, by viewing the time stamp in Windows Explorer. (Click #View, #Details to see this timestamp.)
5.  Restart the PTC Application, and verify that the nmsd process starts in the ‘Task Manager’.
发表于 2003-12-19 07:42:05 | 只看该作者
alpha_unix
hp8k
hpux11_pa32
hpux_pa64
i486_nt
i486_win95
ibm_rs6000
sgi_mips4
sun4_solaris
sun4_solaris64
下载红色的,即i486_nt
链接在此https://download.ptc.com/downloa ... 01/i486_nt/nmsd.zip
GMT+8, 2025-4-27 16:12 , Processed in 0.027916 second(s), 11 queries , Gzip On, Redis On.
