查看: 16367|回复: 6
【题目】超弹非线形分析(1到2分)
发表于 2003-12-18 22:31:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一轴对称橡胶堆,边界条件如图,分析反力-位移曲线!
V=0.499
E=2e5
单轴压缩数据
应变:-0.45,-0.4,-0.35,-0.3,-0.25,-0.2,-0.15,-0.1,-0.05
应力:-256,-128,-64,-32,-16,-8,-4,-2,-1
单轴拉伸数据
应变:0.0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9
应力:0.0,1,1.5,2.0,2.9,3.6,5,7.5,9.7,17
体积试验数据
1 0
0.99 20
发表于 2003-12-21 15:26:15 | 只看该作者
Do you mind to explain the V symbol and Volumetric experiment data?
Thanks!!
发表于 2003-12-21 16:54:18 | 只看该作者
  Thanks!!
https://www.icax.org/viewthread. ... %3D1&page=#pid=&age=60[/url]
发表于 2003-12-21 21:58:00 | 只看该作者
Thanks!! I have seen it but I still get some of question as listed below,
1. ....体积试验数据有所不同,每一行两个数据同样用空格隔开,第二个数为静水压力,但第一个数不是体积应变e,而是相对体积,即1+e (<--- ???),例如体积应变为-0.01,则应该在第一列输入0.99。而且程序假定体积试验为线性关系,拟合时也只拟合出一条直线,所以通常输入两个值即可。数据符号:使体积减小的静水压力为正,这需要注意,如下例:
0 0       <------ Error? or should be  1 0
0.99 20
2. ...mooney还有其他一些推导基于几乎不可压缩,所以对mooney模型而言,输入参数时一定要注意其泊松比应该接近0.5,一般大于0.49。 <---- Error?? Your proxy V=-0.499
I am sorry about these questions but I also want to solve your question for personal interesting!! I hope that you don't mind it.
发表于 2003-12-22 09:28:26 | 只看该作者
  0.99 20
Sorry!
有两个错误:
泊松比=0.499
关于超弹新功能介绍原文有误:
例子应该为:
1 0
0。99 20
谢谢你的细心!
发表于 2003-12-24 06:50:23 | 只看该作者
Dear CAE Master,
  I draw the model on Solidworks and output ACIS format, however,
I still can not solve it since I only can get the compression value on -0.03 meter(not -50 mm). The code is listed below. I would appreciate that you can help me to check and solve it. Thanks!!
ET,1,PLANE183   !* element 183
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2e5
MPDATA,PRXY,1,,0.499
*CREATE,file1.UNIA       !* <-- input compression and tension data
  -0.45 -256
  -0.4 -128
  -0.35 -64
  -0.3 -32
  -0.25 -16
  -0.2 -8
  -0.15 -4
  -0.1 -2
  -0.05 -1
  0 0
  0.1 1
  0.2 1.5
  0.3 2.0
  0.4 2.9
  0.5 3.6
  0.6 5
  0.7 4.5
  0.8 9.7
  0.9 17
*END
TBFT,EADD,1,UNIA,file1.UNIA
/DELETE,file1.UNIA
*CREATE,file1.VOLU
  1 0
  0.99 20
*END
TBFT,EADD,1,VOLU,file1.VOLU
/DELETE,file1.VOLU
TBFT,FADD,1,HYPER,MOON,9
TBFT,SOLVE,1,HYPER,MOON,9,1
TBFT,FSET,1,HYPER,MOON,9
~SATIN,Surface,SAT,'..\',SOLIDS,0
/NOPR
/GO
FINISH
/PREP7
SMRT,3
MSHAPE,0,2D
MSHKEY,0
CM,_Y,AREA
ASEL, , , ,       1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
ANTYPE,0
ANTYPE,0
NLGEOM,1
CUTCONTROL,NOITERPRED,1
FLST,2,1,4,ORDE,1
FITEM,2,3
/GO
DL,P51X, ,UY,0              !*<- boundary constraint on bottom line
DL,       2, ,SYMM           !*<- boundary constraint on left line symm
FLST,2,1,4,ORDE,1
FITEM,2,1
/GO
DL,P51X, ,UY,-0.05  !*<- boundary constraint on top line by moving down 50
/STATUS,SOLU
/STATUS,SOLU
SOLVE
发表于 2003-12-24 15:58:45 | 只看该作者
命令流我不会啊,但粗看了一下,好像没有做接触啊,
GMT+8, 2025-4-30 03:40 , Processed in 0.025044 second(s), 11 queries , Gzip On, Redis On.
