查看: 16871|回复: 2
求助:solidworkd的vc二次开发的向导文件-awx编译错误
发表于 2003-12-27 22:29:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用solidworkd的vc二次开发的向导文件-awx,刚刚生成一个程序框架,其他
一点东西也没有动
然后试着编译一下,老是说下面这个错误,又没有哪个高手指点一下?
LINK : fatal error LNK1104: cannot open file "mfc42u.lib"
发表于 2004-2-6 22:26:04 | 只看该作者
hello,
You should change compiler option to "release or debuge" before you compile the program.
Maybe your system is not win2000 or you have't install unicode options. that's not a problem. just follow what i tell you above.
Good lucky!
发表于 2004-2-6 22:29:46 | 只看该作者
fanwg,
Can you send me the program to secondary develep solidworks or tell the place to download it.
My email is hpeng_1973@sohu.com,hp_eric@avl.com.cn
Thank you!
GMT+8, 2025-4-21 13:58 , Processed in 0.022448 second(s), 14 queries , Gzip On, Redis On.
