查看: 17528|回复: 3
【求助】force pick mode怎么用
发表于 2003-12-31 08:35:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问这个选项有什么作用?
发表于 2003-12-31 09:16:07 | 只看该作者
你用的是几版本的?
发表于 2003-12-31 09:16:52 | 只看该作者
R10
发表于 2003-12-31 09:57:23 | 只看该作者
交互式绘图中,在Drawing属性里,可以设定,投影的线架是否为可选的,如是想要所有的线架都可选,就用这个命令!
下次请先查找在线帮助,帮助里解释得非常清楚!
Pick/No Pick mode
When you create elements using the No Pick mode (Pickable option unchecked),
If you want to make one or several elements pickable back again, perform as follows:
1. Select Edit -> Search from the menu bar and select the element(s) to be modified from the Search dialog box.
2. Select Edit -> Properties option from the menu bar and check the Pickable option from the Properties dialog box.
If you want to make all the elements on a sheet or in a view pickable back again, perform as follows:
1. Click the sheet or the view(s) to be applied the Pick mode from the specification tree.
  2. Select the Force Pick Mode option from the contextual menu.
GMT+8, 2025-4-25 19:34 , Processed in 0.039872 second(s), 10 queries , Gzip On, Redis On.
