查看: 15013|回复: 0
[讨论] 体积特征宏→如何更改面积+体积特征宏。
发表于 2012-10-5 15:10:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自定义宏特征-闷人的体积宏解析
https://www.icax.org/forum.php?mod=viewthread&tid=278864&fromuid=1196481
在这个帖的4楼有个国外体积示例,见下面代码
  1. Option Explicit
  2. Dim swApp As SldWorks.SldWorks
  3. Dim Part As SldWorks.ModelDoc2
  4. Sub main()
  5. Dim ThisFile As String
  6. Dim Methods(8) As String
  7. Dim Names As Variant
  8. Dim Types As Variant
  9. Dim Values As Variant
  10. Dim editBody As body2
  11. Dim swmacrofeaturebydefault As Variant
  12. Set swApp = Application.SldWorks
  13. Set Part = swApp.ActiveDoc
  14. Set editBody = Nothing
  15. 'Define the routines to call
  16. ThisFile = swApp.GetCurrentMacroPathName
  17. Methods(0) = ThisFile
  18. Methods(1) = "MacroFeature_Module1"
  19. Methods(2) = "swmRebuild"
  20. Methods(3) = ThisFile
  21. Methods(4) = "MacroFeature_Module1"
  22. Methods(5) = "swmEditDefinition"
  23. Methods(6) = "" 'A security routine is optional
  24. Methods(7) = ""
  25. Methods(8) = ""
  26. Names = Empty
  27. Types = Empty
  28. Values = Empty
  29. 'Insert the macro feature
  30. Part.FeatureManager.InsertMacroFeature "Volume in Feet", "", (Methods), Names, Types, Values, editBody, swmacrofeaturebydefault
  31. End Sub
  32. Function swmRebuild(app As Variant, Part As Variant, feature As Variant) As Variant
  33. Dim Definition As SldWorks.MacroFeatureData
  34. Dim Objects As Variant
  35. Dim ObjTypes As Variant
  36. Dim SelMarks As Variant
  37. Dim DrwViews As Variant
  38. Set swApp = Application.SldWorks
  39. Set Part = swApp.ActiveDoc
  40. Set Definition = feature.GetDefinition
  41. Definition.GetSelections2 Objects, ObjTypes, SelMarks, DrwViews
  42. Dim vol As Variant
  43. Dim conv As Variant
  44. Dim convRounded As String
  45. Dim prop As Boolean
  46. Dim mass As SldWorks.MassProperty
  47. Set mass = Part.Extension.CreateMassProperty
  48. vol = mass.volume
  49. conv = vol * 35.31466672
  50. convRounded = Round(conv, 3)
  51. prop = Part.DeleteCustomInfo2("", "Volume")
  52. prop = Part.AddCustomInfo3("", "Volume", 30, convRounded + " Cubic Feet")
  53. Debug.Print " Volume = " & mass.volume
  54. End Function
  55. Function swmEditDefinition(app As Variant, Part As Variant, feature As Variant) As Variant
  56. End Function
复制代码
目标需求:如何将国外的体积宏示例,转换为体积+面积的特征宏。
收藏收藏2 分享淘帖 赞一下!赞一下!
GMT+8, 2025-4-27 23:31 , Processed in 0.020360 second(s), 11 queries , Gzip On, Redis On.
