查看: 17415|回复: 1
[求助] 求助UF_OPRBND_set_item_app_data
发表于 2012-10-17 23:42:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UG OPEN API的例子,2d刀路为什么没有FLOOR,请教大侠们??
       UF_CAMBND_append_bnd_from_face(objects, UF_CAM_part,
                                                           entity_list[j], bnd_data_list[j]);
                            UF_CAMBND_append_bnd_from_face(objects, UF_CAM_blank,
                            UF_CAMBND_append_bnd_from_face(objects, UF_CAM_check,
                            UF_CAMBND_append_bnd_from_face(objects, UF_CAM_trim,
UF_CAM_geom_type_eenum UF_CAM_geom_type_e
The CAM geometry types.
UF_CAM_part
UF_CAM_blank
UF_CAM_check
UF_CAM_trim
UF_CAM_cut_area
UF_CAM_wall
UF_CAM_drive
                 Copyright (c)  2001 Unigraphics Solutions, Inc.
                        Unpublished - All Rights Reserved
* DESCRIPTION -                                                              *
*   This program shows how to use the following UG/Open API routine(s):      *
*   UF_CAMBND_append_bnd_from_curve                                          *
*   UF_CAMBND_append_bnd_from_face                                           *
*   UF_CAMBND_ask_boundaries                                                 *
*   UF_CAMBND_ask_boundary_app_data                                          *
*   UF_CAMBND_ask_boundary_data                                              *
*   UF_CAMBND_ask_boundary_items                                             *
*   UF_CAMBND_ask_item_app_data                                              *
*   UF_CAMBND_ask_item_entity                                                *
*   UF_CAMBND_delete_boundaries                                              *
*   UF_CAMBND_delete_boundary                                                *
*   UF_CAMBND_set_boundary_app_data                                          *
*   UF_CAMBND_set_item_app_data                                              *
* PROGRAM DESCRIPTION -                                                      *
*   This example requires an open part, a manufacturing setup, and           *
*   one or more highlighted geometry groups or operations.                   *
/***************************** Include Files **********************************/
#include <stdlib.h>
#include <uf.h>
#include <uf_obj.h>
#include <uf_object_types.h>
#include <uf_part.h>
#include <uf_ui.h>
#include <uf_ui_ont.h>
#include <uf_cambnd.h>
#include <uf_cam.h>
#include <uf_disp.h>
#define     MAX_BND      20
static UF_CAMBND_boundary_data_p_t create_and_init_bnd_data
    UF_CAM_boundary_type_t   type,
    int                      plane_type,
    double                   *origin,
    double                   *matrix,
    UF_CAM_material_side_t   material_side,
    int                      ignore_holes,
    int                      ignore_islands,
    int                      ignore_chamfers,
    UF_CAMBND_app_data_p_t   app_data
static UF_CAMBND_app_data_p_t create_and_init_bnd_app_data(void);
static int init_proc1(UF_UI_selection_p_t select, void *user_data);
static int init_proc2(UF_UI_selection_p_t select, void *user_data);
static void do_cambnd_api(void)
    UF_CAMBND_boundary_data_p_t  bnd_data, bnd_data_list[MAX_BND];
    UF_CAMBND_app_data_p_t       app_data_list[MAX_BND];
    tag_t                        part_tag, *objects, entity_list[MAX_BND];
    int                          i, j, object_count, part_count, part_item_count;
    int                          type, subtype;
    UF_CAMBND_boundary_t         *part_bnd_list;
    UF_CAMBND_item_t             *part_item_list;
    /* Get the displayed part. */
    part_tag = UF_PART_ask_display_part( );
    if( part_tag != null_tag )
        /* Get the highlighted/selected objects from Navigation Tool. */
        UF_UI_ONT_ask_selected_nodes( &object_count, &objects );
        if (object_count > 0)
            tag_t     eid, view;
            double    cursor[3], origin[3], matrix[9];
            int       entity_count, response;
            char      cue_face[]   = "Select faces";
            char      cue_edge[]   = "Select edges";
            char      title[]      = "Boundary Selection";
            entity_count = 0;
            /* Allow the user to select faces. */
            while (TRUE)
                UF_UI_select_with_single_dialog(cue_face, title,
                                                UF_UI_SEL_SCOPE_NO_CHANGE, init_proc1, NULL,
                                                &response, &eid, cursor, &view);
                if (response == UF_UI_OBJECT_SELECTED)
                    entity_list[entity_count] = eid;
                    /* Allocate the memory for the boundary data of an item without app data.  */
                    bnd_data_list[entity_count] = create_and_init_bnd_data(UF_CAM_boundary_type_closed,
        1, origin, matrix,
        UF_CAM_material_side_out_right,
        0, 0, 0, NULL);
                    entity_count++;
                else if (response == UF_UI_OK || response == UF_UI_CANCEL ||
                         response == UF_UI_BACK)
                    /* Geometry selection is finished. */
                    break;
            /* Append the face boundaries. */
            if (entity_count > 0)
                for(i=0; i<object_count; i++)
                    UF_OBJ_ask_type_and_subtype(objects, &type, &subtype);
                    /* The object type must be Operation or Geometry Group. */
                    if( type == UF_machining_operation_type || type == UF_machining_geometry_grp_type)
                        for (j=0; j<entity_count; j++)
            /* Free the boundary data. */
            for (i=0; i<entity_count; i++)
                UF_free(bnd_data_list);
            entity_count = 0;
            /* Allow the user to select edges. */
            while (TRUE)
                UF_UI_select_with_single_dialog(cue_edge, title,
                                                UF_UI_SEL_SCOPE_NO_CHANGE, init_proc2, NULL,
                    app_data_list[entity_count] = create_and_init_bnd_app_data();
                    entity_count++;
                    break;
            /* Append curve boundaries. */
                bnd_data = create_and_init_bnd_data(UF_CAM_boundary_type_open,
                                                    1, origin, matrix,
                                                    0, 0, 0, NULL);
                        UF_CAMBND_append_bnd_from_curve(objects, UF_CAM_part, entity_count,
                                                        entity_list, bnd_data, app_data_list);
                        UF_CAMBND_append_bnd_from_curve(objects, UF_CAM_blank, entity_count,
                        UF_CAMBND_append_bnd_from_curve(objects, UF_CAM_check, entity_count,
                        UF_CAMBND_append_bnd_from_curve(objects, UF_CAM_trim, entity_count,
                /* Free memory. */
                    UF_free(app_data_list);
                UF_free (bnd_data);
            UF_CAMBND_ask_boundaries(objects[0], UF_CAM_part, &part_count, &part_bnd_list);
            for (i=0; i<part_count; i++)
                UF_CAMBND_boundary_data_t boundary_data;
                UF_CAMBND_app_data_t      app_data;
                UF_CAMBND_ask_boundary_data(part_bnd_list, &boundary_data);
                UF_CAMBND_ask_boundary_app_data(part_bnd_list, &app_data);
                UF_CAMBND_set_boundary_app_data(objects[0], UF_CAM_part, part_bnd_list, &app_data);
                UF_CAMBND_ask_boundary_items(part_bnd_list, &part_item_count, &part_item_list);
                for (j=0; j<part_item_count; j++)
                    tag_t                 entity;
                    UF_CAMBND_app_data_t  item_app_data;
                    UF_CAMBND_ask_item_entity(part_item_list[j], &entity);
                    UF_CAMBND_ask_item_app_data(part_item_list[j], &item_app_data);
                    UF_CAMBND_set_item_app_data(objects[0], UF_CAM_part, part_bnd_list,
                                                part_item_list[j], NULL);
                UF_CAMBND_delete_boundary(objects[0], UF_CAM_part, part_bnd_list);
            UF_CAMBND_delete_boundaries(objects[0], UF_CAM_blank);
            UF_CAMBND_delete_boundaries(objects[0], UF_CAM_check);
            UF_CAMBND_delete_boundaries(objects[0], UF_CAM_trim);
    return;
/* Selection initialization procedures.*/
    void* user_data
    int num_triples = 1;
    UF_UI_mask_t mask_triples[] = {UF_solid_type, 0, UF_UI_SEL_FEATURE_ANY_FACE};
    /* enable only lines and edges */
    if((UF_UI_set_sel_mask(select,
                           UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,
                           num_triples, mask_triples)) == 0)
        return (UF_UI_SEL_SUCCESS);
    else
        return (UF_UI_SEL_FAILURE);
    void* user_data
    UF_UI_mask_t mask_triples[] = {UF_solid_type, 0, UF_UI_SEL_FEATURE_ANY_EDGE};
    else
    int                      plane_type,
    double                   *origin,
    double                   *matrix,
    int                      ignore_holes,
    int                      ignore_islands,
    UF_CAMBND_boundary_data_p_t bnd_data;
    int                         i, err_code;
    bnd_data = (UF_CAMBND_boundary_data_p_t) UF_allocate_memory(
                                             sizeof(UF_CAMBND_boundary_data_t), &err_code);
    bnd_data->boundary_type = type;
    bnd_data->plane_type = plane_type ;
    for (i=0; i<3; i++)
        bnd_data->origin = origin ;
    for (i=0; i<9; i++)
        bnd_data->matrix = matrix ;
    bnd_data->material_side = material_side;
    bnd_data->ignore_holes = ignore_holes ;
    bnd_data->ignore_islands = ignore_islands ;
    bnd_data->ignore_chamfers = ignore_chamfers ;
    bnd_data->app_data = app_data;
    return(bnd_data);
    UF_CAMBND_app_data_p_t  app_data;
    int                     err_code;
    app_data = (UF_CAMBND_app_data_p_t) UF_allocate_memory(
                                          sizeof(UF_CAMBND_app_data_t), &err_code);
    if (err_code)
return(NULL);
    /* Set flags. */
    app_data->has_stock = 1;
    app_data->has_tolerances = 0 ;
    app_data->has_feedrate = 0 ;
    app_data->has_blank_distance = 0;
    app_data->has_tool_position = 0;
    /* Set values. */
    app_data->stock = 0.1 ;
    app_data->tolerances[0] = 0.1 ;
    app_data->tolerances[1] = 0.1 ;
    app_data->feedrate_unit = UF_CAM_feedrate_unit_per_minute ;
    app_data->feedrate_value = 0.1 ;
    app_data->blank_distance = 0.0 ;
    app_data->tool_position = UF_CAM_tool_position_tanto;
    return(app_data);
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int param_len)
    UF_initialize();
    do_cambnd_api();
    UF_terminate();
int ufusr_ask_unload(void)
return (UF_UNLOAD_IMMEDIATELY);
发表于 2012-10-21 01:32:42 | 只看该作者
自己结贴
GMT+8, 2025-9-18 21:40 , Processed in 0.085601 second(s), 11 queries , Gzip On, Redis On.
