查看: 16029|回复: 0
CAA 循环中出现更新问头
发表于 2012-11-3 10:34:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  //通过拓扑获取选定边界上小的边界曲线段的个数,对每个小曲线段进行外插延伸
        int index;
for(index=1; index<=LISTCellB.Size();index++)
         //将每个小曲线段小曲线段特征化
         CATIGSMBoundary_var spGSMBoundary = pFact->CreateBoundary(spEdgeElem,SpecObj2,BOUNDARY_NO_PROPAG
         if (NULL_var == spGSMBoundary){cout<<"Create Boundary Failed!"<<endl;}
        CATIGSMExtrapol_var _spExtrapolSurf = pFact->CreateExtrapOl(spGSMBoundary,SpecObj2,ickStart,CATGSMTangentContinuity,CATGSMTangentBorder,FALSE,CATGSMNoPropagation);//创建外插延伸
        if(_spExtrapolSurf==NULL_var)
              cout<<"创建延伸失败" <<endl;
              continue;
       else
              cout<<"创建延伸成功"<<endl;
             CATISpecObject_var spSpecTmp=_spExtrapolSurf;
              if (spSpecTmp==NULL_var){cout<<"获取CATISpecObject类型失败"<<endl;}
             CATISpecObject_var ispInputParent=spGsmTool;
             rcc=InsertInProceduralView(spSpecTmp,ispInputParent);//放到GSMTOOL里面
             HRESULT rc=ExtrapolUpdate(spSpecTmp);
            if (FAILED(rc))
                 cout<<"无法更新!!!"<<endl;
                ispInputParent->Remove(spSpecTmp);
              spSpecTmp=NULL_var;
              continue;
           else
              cout<<"成功创建外插延伸,开始判断"<<endl;
             //判断方法:将外插延伸得到曲面的四个角点投影,并通过直线的夹角判断
             if (_piAngle<=0.05)
                  cout<<"第"<<index<<"次试拉伸的曲面片满足要求"<<endl;
                  break;
             else
                     cout<<"该试拉伸的曲面片不满足要求,继续拉伸"<<endl;
                     CATISpecObject_var ispFather = spSpecTmp->GetFather();
                     ispFather->Remove(spSpecTmp);
                     spSpecTmp=NULL_var;
现在出现的问题就是将第一次外插延伸出的曲面删去以后,从第二次外插延伸开始出现更新问题,说是The Handle is NULL;
请问高手,哪边除了问题。在线等答案
GMT+8, 2025-4-20 15:07 , Processed in 0.023320 second(s), 14 queries , Gzip On, Redis On.
