查看: 13844|回复: 4
如何建立草图里面元素间的约束?
发表于 2012-11-20 21:13:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CATI2DWFFactory_var spWF2DFactOnSketch(spSketch);
  // Creates the elements of the sketch
  double pt1[2] = {10., 5.},
         pt2[2] = {-10., 5.},
         pt3[2] = {-10., -5.},
         pt4[2] = {10., -5.};
  // Edits the sketch and draws the lines and the endpoints.
  spSketch->OpenEdition();
  CATISpecObject_var spLine1 = spWF2DFactOnSketch->CreateLine(pt1,pt2);
  CATISpecObject_var spLine2 = spWF2DFactOnSketch->CreateLine(pt2,pt3);
  CATISpecObject_var spLine3 = spWF2DFactOnSketch->CreateLine(pt3,pt4);
  CATISpecObject_var spLine4 = spWF2DFactOnSketch->CreateLine(pt4,pt1);
  CATISpecObject_var spCircle = spWF2DFactOnSketch->CreateCircle(pt4,50,0,3.14);
如上 我打算创建一个矩形框  并以Pt4为圆心创建圆弧 。但是,由于没有约束,这些线条与圆在草图中都是活动的,并没有固定下来。
求帮助  谢谢!
发表于 2012-11-21 08:31:05 | 只看该作者
CATI2DConstraintFactory
CATI2DConstraintFactory_var spConstraint2DFactory(spSketch);
spConstraint2DFactory->CreateConstraint( spLine1, NULL, NULL, NULL, NULL, NULL, NULL,  Cst2DType_Horizontal, 0, 0 );
spConstraint2DFactory->CreateConstraint( spLine2, NULL, NULL, NULL, NULL, NULL, NULL,  Cst2DType_Vertical, 0, 0 );
spConstraint2DFactory->CreateConstraint( spLine3, NULL, NULL, NULL, NULL, NULL, NULL,Cst2DType_Horizontal, 0, 0 );
spConstraint2DFactory->CreateConstraint( spLine4, NULL, NULL, NULL, NULL, NULL, NULL,  Cst2DType_Vertical, 0, 0 );
spConstraint2DFactory->CreateConstraint( spLine2, NULL, NULL, NULL, NULL, NULL, NULL, Cst2DType_Length, 0, 0 );
spConstraint2DFactory->CreateConstraint( spLine2, NULL, spLine4, NULL, NULL, NULL, NULL, Cst2DType_Distance, 0, 0 );
发表于 2012-11-21 10:13:16 | 只看该作者
谢谢 丽丽!    在草图中 如何将一个创建的 CATI2DCurve  与CATI2DPoint   定义为相合呢?    或者两个CATI2DPoint  间定义为重合。
发表于 2012-11-21 10:24:45 | 只看该作者
知道了  用Cst2DType_On 命令
发表于 2012-11-21 10:53:40 | 只看该作者
恩恩,根据需要创建的约束类型 设置参数CAT2DCstType
GMT+8, 2025-1-30 13:00 , Processed in 0.021846 second(s), 10 queries , Gzip On, Redis On.
