查看: 15859|回复: 3
UG NX Translator Problems
发表于 2004-1-2 15:24:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
One customer pass me some .DXF files generated from FastCAD, and ask me to convert them into UG or SolidEdge, and Problems come:
   1. I try to import into UG NX, but quite a lot of dimensions lost. As shown in Imagine 1.
发表于 2004-1-2 15:28:15 | 只看该作者
2. Then I use Ideas to import the DXF file, it works well.....and the diemensions can be edited.......but, then I use UG to open the Ideas file that saved, it comes out the drawing, but all those dimensions can not be edited. for example, you can move the arrow of the dimensions to anywhere, line is line, text is text, totally no use any more.
发表于 2004-1-2 15:30:41 | 只看该作者
3. How can I solve the problems?
   UG NX traslator is worse than IDEAS translator?
   I want them to be converted into UG or SolidEdge...
   Thanks.
发表于 2004-1-2 15:33:01 | 只看该作者
4.File
GMT+8, 2025-4-28 13:58 , Processed in 0.023881 second(s), 12 queries , Gzip On, Redis On.
