查看: 16085|回复: 2
小问题,
发表于 2004-1-30 11:45:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如图
发表于 2004-1-30 13:04:51 | 只看该作者
只用在  cut file
Arc Fit - allows programs to be arc fitted before postprocessing, (it should be equivalent to running "CLARCFIT" on the cut file). It will normally only make a difference to groups of moves which are in principal planes (e.g. if a set of moves are in X or Y and not Z you should see G2 and G3 in the tape file as well as G1).
发表于 2004-2-5 08:43:50 | 只看该作者
ddddddddddddddd
GMT+8, 2025-4-6 13:49 , Processed in 0.022348 second(s), 12 queries , Gzip On, Redis On.
