查看: 12532|回复: 0
[求助] 新人求问catia编程方面问题
发表于 2013-12-5 22:45:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
'COPYRIGHT DASSAULT SYSTEMES 2000-2001
Option Explicit
Dim Language
Language="VBSCRIPT"
' Purpose:      This macro calls the kinematics solver
'               and applies the computed motion to a
'               part of the mechanism
'               in a specific product document
' Assumptions:  The product document used as input is result of the
'               CAAKiiMechanismCreation use case
' Author:
' Languages:    VBScript
' Version:      V5R6
' Locales:      US English
Sub CATMain()
    ' 1-Prolog
    ' 1.a-Declare required variables: command set, motion matrix
    Dim dValcmd(1)
    Dim dMotion(11)
    ' 1.b-Retrieve the root product
    Dim oRootProduct
    Set oRootProduct = CATIA.ActiveDocument.Product
    ' 1.c-Retrieve the Mechanisms as a TechnologicalObject of the Product
    Dim cTheMechanisms
    Set cTheMechanisms = oRootProduct.GetTechnologicalObject("Mechanisms")
    ' 1.d-Take 1st mechanism found, and first moving part
    Dim oFirstMechanism
    Set oFirstMechanism = cTheMechanisms.Item(1)
    ' 2-Retrieve number of moving parts, and first one
    Dim iNbProd
    iNbProd = oFirstMechanism.NbProducts
    Dim oMovingPart
    Set oMovingPart = oFirstMechanism.GetProduct(1)
    ' 3-Retrieve current command values
    oFirstMechanism.GetCommandValues dValcmd
    ' 4-Solve for other command values
    ' 4.a-Create another command set
    dValcmd(0) = dValcmd(0) + 10
    ' 4.b-Apply the command set
    oFirstMechanism.PutCommandValues dValcmd
    ' 5-Retrieve motion for a part after solving and apply it
    ' 5.a-Retrieve motion for a part after solving
    oFirstMechanism.GetProductMotion oMovingPart,dMotion
    ' 5.b-Apply the motion to the part
    oMovingPart.Move.Apply dMotion
End Sub
上面这是CATIA自带的程序  但是运行多个运动副机构的时候在oFirstMechanism.GetCommandValues dValcmd出现错误 求高手指点
该贴已经同步到 我就是小黑人的微博
GMT+8, 2025-4-15 08:59 , Processed in 0.025009 second(s), 15 queries , Gzip On, Redis On.
