查看: 17338|回复: 13
【求助】请教1个简单小问题---视角含义
发表于 2004-2-4 11:59:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
isometric trimetric dimetric 怎么区分?他们是怎样具体定义的?
发表于 2004-2-4 12:55:16 | 只看该作者
isometric愛傻駡街
trimetric菜馬切
dimetric呆麽且
:D
发表于 2004-2-4 13:51:33 | 只看该作者
:O)
Francis wrote:
isometric愛傻駡街
  trimetric菜馬切
  dimetric呆麽且
  :D
:O)
头像被屏蔽
发表于 2004-2-4 15:21:16 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-2-5 08:43:59 | 只看该作者
感谢3楼4楼的热心帮助。名字我查词典可以找到,可是不知道其真正的含义。
头像被屏蔽
发表于 2004-2-5 09:32:04 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-2-5 09:46:13 | 只看该作者
非常感谢楼上,真的很感谢,我英文一般,贴出来大家共享。预知详细,请到楼上老兄提供的网页。
Isometric
Isometric projection is one of the three forms of axonometric projection. In isometric projection the angles between the projection of the axes are equal i.e. 120[$ordm]. It is important to appreciate that it is the angles between the projection of the axes that are being discussed and not the true angles between the axes themselves which is always 90[$ordm].
发表于 2004-2-5 09:46:47 | 只看该作者
Isometric
发表于 2004-2-5 09:47:45 | 只看该作者
Trimetric
In trimetric projection the projection of the three angles between the axes are unequal. Thus, three separate scales are needed to generate a trimetric projection of an object. The scales are constructed using the same method described in isometric and dimetric projection. An example below shows the method of construction for each of the scales.
发表于 2004-2-5 09:48:01 | 只看该作者
Trimetric
GMT+8, 2025-4-26 15:10 , Processed in 0.025234 second(s), 12 queries , Gzip On, Redis On.
