[已解决] 如何取出多實體零件中單一實體的體積值
发表于 2014-8-6 13:52:42 | 只看该作者
補上在api找到的資料
This example show how to get the mass of the selected component of an assembly.
' Preconditions:
' 1. Specified assembly document exists.
' 2. Open the Immediate window.
' 3. Run the macro.
' Postconditions: Mass of the selected component printed to
' Immediate window.
Option Explicit
Sub main()
Dim swApp As SldWorks.SldWorks
Dim swModelDoc As SldWorks.ModelDoc2
Dim comp As Component2
Dim compbody As Variant
Dim bodyInfo As Variant
Dim val As Double
Dim params As Variant
Dim swMass As SldWorks.MassProperty
Dim boolstatus As Boolean
Dim errors As Long
Dim warnings As Long
Set swApp = Application.SldWorks
Set swModelDoc = swApp.OpenDoc6("C:\program files\solidworks corp\solidworks\samples\tutorial\edraw\claw\claw-mechanism.sldasm", swDocASSEMBLY, swOpenDocOptions_Silent, "", errors, warnings)
boolstatus = swModelDoc.Extension.SelectByID2("collar-1@claw-mechanism", "COMPONENT", 0, 0, 0, False, 0, Nothing, swSelectOptionDefault)
Set comp = swModelDoc.SelectionManager.GetSelectedObject6(1, 0)
compbody = comp.GetBodies3(swAllBodies, bodyInfo)
Set swMass = swModelDoc.Extension.CreateMassProperty
boolstatus = swMass.AddBodies((compbody))
swMass.UseSystemUnits = False
val = swMass.mass
Debug.Print "Mass - " & val
val = swMass.Volume
Debug.Print "Volume - " & val
val = swMass.Density
Debug.Print "Density - " & val
val = swMass.SurfaceArea
Debug.Print "Surface area - " & val
params = swMass.CenterOfMass
Debug.Print "Center of mass - X: " & params(0) & " ,Y: " & params(1) & ", and Z: " & params(2)
End Sub
发表于 2014-8-6 16:17:14 | 只看该作者
Francis 发表于 2014-8-6 13:01
補充
mass 改為 volume
還要再請教了,
如圖,原本 "項次1" 是看不到 "屬性" 的,
找到大師的宏執行才顯示,除了用宏取出,沒其他方式可激活嗎?
已解決,謝謝!
发表于 2014-8-6 16:30:12 | 只看该作者
梁叔可否放一個看不見屬性的檔案給阿丹測試一下?
我這邊2012沒問題的,除料清單「更新」後就可以使用了。
发表于 2014-8-6 16:40:45 | 只看该作者
我這邊2012沒問題的,除料清單「更新」後就可以使用了。 ...
謝謝丹版主指導,
就是要做一次更新,
之前根本沒研習用到焊件,所以問題特別多!
发表于 2014-8-6 16:55:52 | 只看该作者
要在"切割清單"的每一個文件夾的加上"體積"屬性, 方法如下:
1. 刪除"切割清單"內所有現有的文件夾.
2. 對著第一個特徵(原點下一個)按右鍵
3. 加入"體積"屬性(下拉清單有個 volume 的, 不需自行鍵入)
4. 對著實體文件夾按右鍵點選更新
5. 所有新建立的切割清單就有體積屬性, 無需逐一手動加上的.
参与人数 1技术 +1 收起 理由
gt.adan + 1 謝謝悶大教程!
发表于 2014-8-6 17:08:33 | 只看该作者
要是提取其數據更是便中之便, 註釋鍵入"$PRPWLD:"體積""即可, 然後 copy & paste 到不同的實體, 無需逐一鍵入.
可能蛋大又會問悶人"是否經常使用到$PRP語句", 讓悶人無言.
参与人数 1技术 +1 收起 理由
gt.adan + 1 不問了,謝謝悶大教程!
发表于 2014-8-6 17:25:50 | 只看该作者
顶哦,能再详细点啊
18
发表于 2014-8-6 17:29:09 | 只看该作者
又發現個問題
零件屬性的 "值" 好像一定要從 "除料清單屬性" 做好複製過去,
直接打字是不行的,是這樣嗎??
发表于 2014-8-6 17:45:02 | 只看该作者
ryouss 发表于 2014-8-6 17:29
又發現個問題
不對,請梁叔注意大小寫的問題。
发表于 2014-8-6 17:59:09 | 只看该作者
如果不是有特別要求,或是不在工程圖中調用,直接鍵入也行。
無需在屬性欄位再連結一次。梁叔可見我的屬性欄位是空的。
GMT+8, 2025-4-20 01:14 , Processed in 0.029510 second(s), 15 queries , Gzip On, Redis On.
