查看: 17708|回复: 1
请大家看看这个课题
发表于 2002-2-8 07:45:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个长方体板形零件,内部由聚氨酯发泡料填充。外壳为PVC塑料。上表面随意放置一些铁制零件。
沿长度方向有三个均布支撑。问怎样求三个支撑的反力?
发表于 2002-2-9 08:22:25 | 只看该作者
If material properties are well defetermined, i,e, the stress-strain curve for PVC and 聚氨酯发泡料,materials is non-linear elastic or elastic-plastic/) By using Cosmos/Designstar 3.0, the problem should be sloved easily.Cosmos/Design Star 3.0 has the capability to obtain reaction force. Good Luck!
GMT+8, 2025-4-17 20:53 , Processed in 0.020771 second(s), 13 queries , Gzip On, Redis On.
