查看: 17853|回复: 10
【求助】UG_HPLaserJet 5100Le如何配置?
发表于 2002-9-5 16:26:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我有壹HP_LASERJET 5100Le的激光打印机,按UG_HPGL/2激光打印机的设置参数(SWITCHES=/2/LJ/SP=MW/D=600/AR)配置了打印机,但打印A3和A4时却不能准确出图,只打印A4幅面大小的图形,且无法充满A4幅面.(如WINDOWS界面打印设置纸边距一样,原点左下两边空了一定的边距)!
请教各位前辈有何方法解决?
谢谢!
发表于 2002-9-5 23:17:15 | 只看该作者
HP5000LE
   Despooler Name          = UGIIHP
  &nbsplotter Vendor          = HEWLETT-PACKARD
  &nbsplotter Type            = Electrostatic
   Number Of Pens          = 8
   Controller ID           =
  &nbsplotter Model           = 7600
  &nbsplotter Switches        = /2/LJ/SP=MW/AR
   Media Control           = Continuous Form
   Distance Between Plots  = 0
   Output Mode             = Queue
  &nbsplotter Com Line        =
   System Queue Name       = \\GCEB\HP5000LE
   Directory Pathname      =
   Tape Density            = 1600
   Message Interval        =
   Message Com Line        =
   Horizontal Maximum      = 0
   Vertical Maximum        = 0
   Steps Per Inch          = 1016
   Optimization Level      = None
发表于 2002-9-6 08:59:23 | 只看该作者
楼上的大哥:
            HP DeskJet 1125C 喷墨打印机又如何配置?
发表于 2002-9-8 04:22:42 | 只看该作者
Plotter Switches = /2/LJ/SP=MW/AR
请查看手册关于Switches的篇章
可以分别设A3和A4的PLOTQ
发表于 2002-9-8 13:34:02 | 只看该作者
如何在UG中使用HP LaserJet5000激光打印机
对于 HP LaserJet 5000 激光打印机 ,起初我们配置打印机的数据如下:
HPLJ5000
Plotter Vendor = HEWLETT-PACKARD
Plotter Type = Electrostatic
Number Of Pens = 8
Controller ID =
Plotter Model = 7600
Plotter Switches = /2/LJ/AR
Output Mode = Queue
Plotter Com Line =
System Queue Name = \\SERVER\HPLJ5000
Tape Density = 1600
Message Interval =
Message Com Line =
在使用时,每打印一张图纸,便多带出一页白纸,后来把打印机的参数调整到如下所示:
HPLJ5000
Despooler Name = UGIIPS
Plotter Vendor = POSTSCRIPT
Number Of Pens = 8
Controller ID =
Plotter Switches = /A3/AR/AS/MO/BS=0x0
Output Mode = Queue
Plotter Com Line =
Tape Density = 1600
Message Interval =
Message Com Line =
Steps Per Inch = 1400
就是绘图语言由HPGL/2语言改为Postscript语言,这样不仅去掉了多打印出来的一页,而且打印的幅面还可以控制 (A3 and A4 ).
发表于 2002-9-9 13:30:26 | 只看该作者
谢谢楼上各位大哥!但是HP LaserJet5000Le激光打印机不支持Postscript语言,所以仍旧不能准确打印!
***我有壹HP_LASERJET 5100Le的激光打印机,按UG_HPGL/2激光打印机的设置参数(SWITCHES=/2/LJ/SP=MW/D=600/AR)配置了打印机,但打印A3和A4时却不能准确出图,只打印A4幅面大小的图形,且无法充满A4幅面.(如WINDOWS界面打印设置纸边距一样,原点左下两边空了一定的边距)!
请教各位前辈有何方法解决?
谢谢! ***
发表于 2002-9-9 17:08:35 | 只看该作者
不会吧,我公司的HPLJ5000原先情况和你一样,改过以后就可以了呀!
发表于 2002-9-9 21:48:54 | 只看该作者
哈哈,这问题我也遇到过,没急死,不是你打印配置的问题,是本身打印机的毛病,你把打印机的默认纸张设为a3跗面的,具体参见打印说名数,估计应该没事了,默认下打印机纸张为4的,注意一定要在打印机中设置就是按那个该死的机器按谬调整一下,在window下调是不管用的,你的打印几能打4的应该能打3的,是不是只出纸没图象???
发表于 2002-9-18 20:06:30 | 只看该作者
谢谢楼上各位大哥!但是HP LaserJet5000Le激光打印机不支持Postscript语言,按Plotter Switches = /A3/AR/AS/MO/BS=0x0配置打出乱码!
按Plotter Switches = /2/LJ/AR 配置可以打A4纸但无法充满A4幅面.(如WINDOWS界面打印设置纸边距一样,原点左下两边空了一定的边距)!
发表于 2002-9-19 13:13:35 | 只看该作者
苦闷,好不容易能打图了,可是没有线宽,文字是灰色的,计算机名为cad257,打印机共享名为hpdesign,打印机就装在本机上,是hp750c,域用户登录,如下设置:
PLRID=DJ750C
INTEGRITY_ID=0000
DSPNM=UGIIHP
PLTVEN=HEWLETT-PACKARD
TYPE=E
MODEL=7600
SWITCHES=/2/SP=CN/D=300/AR
OUTMOD=2
COMLN=
QUENAM=\\CAD257\HPDESIGN
OUTDIR=E:\PART
NPENS=8
DXBET=0
STPSZ=1016
  打印 对话框的 确定键 始终是灰的,不可用,点击 输出绘图文件 再确认就输出到打印机了,我设置SWITCHES=/2/SP=MX/D=300/AR也不行,哪位大侠有高招,请不吝赐教
GMT+8, 2025-4-23 01:55 , Processed in 0.024982 second(s), 11 queries , Gzip On, Redis On.
