查看: 10955|回复: 1
[求助] 关于API帮助文档内代码的疑问求助
发表于 2014-11-20 23:24:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
问题1,我按照帮助文档的代码引用,编译器却提示如上错误(
在项目引用管理器里面我就选择下面三项,没问题吧)
问题2,下面代码蓝底的“swApp”是哪来的,找不到申明
问题3,我看到网上好多都是用“
swApp = CreateObject("SldWorks.Application")”引用接口的,为什么呢
Imports
SOLIDWORKS.Interop.sldworks
Imports SolidWorks.Interop.swconst
Imports System.Runtime.InteropServices
Imports System
Imports System.Diagnostics
Partial Class SolidWorksMacro
Dim swModel As ModelDoc2
Dim selMgr As SelectionMgr
Dim swPart As PartDoc
Dim mirrorFeature As Feature
Dim myFeature As Feature
Dim resultPart As ModelDoc2
Dim mirrorFeatData As MirrorPartFeatureData
Dim refPlane As RefPlane
Dim facePlane As Face2
Dim mirrorOptions As Integer
    Dim faceType As Integer
    Dim selType As swSelectType_e
Dim message As String
    Sub main()
        swModel = swApp.ActiveDoc
If swModel Is Nothing Then Exit Sub
        If swModel.GetType <> swDocumentTypes_e.swDocPART Then Exit Sub
        selMgr = swModel.SelectionManager
If selMgr.GetSelectedObjectCount2(-1) = 0 Then Exit Sub
        selType = selMgr.GetSelectedObjectType3(1, -1)
If Not (selType = swSelectType_e.swSelDATUMPLANES Or selType = swSelectType_e.swSelFACES) Then Exit Sub
        swPart = swModel
    .............字数限制,省略
End If
    End Sub
    Public swApp As SldWorks
End Class
发表于 2014-11-21 09:30:03 | 只看该作者
为什么图片无法显示出来{:soso_e105:}
GMT+8, 2025-4-22 04:26 , Processed in 0.023312 second(s), 11 queries , Gzip On, Redis On.
