查看: 10852|回复: 0
[求助] 请教版主AM_PLOT命令的使用方法
发表于 2014-11-23 00:20:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想调用PDF打印机,自动打印二维图,打入命令后出错,不得其解,请版主帮忙指点一下迷津。谢谢了先呀
AM_PLOT terminate actionAM_PLOT plots a drawing, sheet, viewport or specified box to a selected plotter. Syntax                  +---------------------------------<----------------------------------------+                  |        |                  |                                         |                  |                                         |---->(AM_PLOT)----+---(:OUTPUT)----+-----(RAWING)-----------------------+------------------+----->                  |                |                                      |                 |                  |                +-----(:SHEET)-------------------------+             |                  |                |                                      |             |                  |                +-----(:VIEWPORT)----------------------+             |          |                |                                      |             |          |                +-----(:BOX)---|1st pnt|---|2nd pnt|---+             |                  |                                         |                  |                                         |                  |                                         |                  +---(:CONTENTS)--+---(:VISIBLE)------+-------------------------------------+----->                  |                |                   |                         |                  |                +---(:ALL)----------+                     |                  |                                         |               |        |                  +---(:SCALE)-----+---(:FIT)------+-----------------------------------------+----->                  |                |               |                                         |                  |                +---(:FACTOR)---+                         |                  |                                         |                  |                                         |                  +(*)-----(:FACTOR)---|factor|----------------------------------------------+                  |        |                  |                                         |                  +---(OSITION)----+---(:CENTER)----+--------------------------------------+----->                  |                  |                |                             |                  |                  +---(EFT)------+                         |                  |                                         |                  |                                         |                  +(**)---(APERSIZE)----|frame type|---------------------------------------+----->                  |        |                  |                                         |          |                                         |                  +---(:ORIENTATION)---+---(ORTRAIT)----+----------------------------------+----->                  |                    |                  |                                  |                  |                    +---(ANDSCAPE)---+                     |          |                    |                  |                     |          |                    +---(:USER)--------+                     |          |                                         |                   |                                         |                  +(***)-----(LOT_ANGLE)---|angle|-----------------------------------------+----->          |        |          |                                         |          +----------(:TRANSF_LABEL)---|name|----------------------------------------+----->          |                                             |          |                                             |          +--(ATTERN_LENGTH)---(:ALL)--+----------|length|-----------+--(:ACCEPT)--+----->          |                 |                       |             |          |                 |                                |             |          |                 +--(:OFF)-+-|1...7|--|length|-+             |                  |                           |                   |             |          |                                        +-------<-----------+             |          |                                         |           |                                         |          +(**)-------(EVICE)-------|plotter|--------------------------------------+----->          |                                                     |                         |        |                   +(**)-------(ESTINATION)--|plot dest|------------------------------------+----->          |        |          |                                         |          +(****)-----(:SHOW_DIALOG)---+---(:ON)----+--------------------------------+----->                  |                            |            |                                |                  |                            +---(:OFF)---+                     |          |                                                           |          +----------------------------------->--------------------------------------+
GMT+8, 2025-4-13 08:36 , Processed in 0.112429 second(s), 12 queries , Gzip On, Redis On.
