查看: 11825|回复: 2
[求助] CATIA 二次开发语法循环问题
发表于 2014-12-9 11:06:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自已录了一个CATIA的宏(快速生成创成式制图),但不知道怎么去简化它,用循环语法表达,而不是一个一个的去叠加,详情见下图,红色字体与黑色字体分别是两个循环,请各位二次开发前辈指点一下,谢谢。
Language="VBSCRIPT"
Sub CATMain()
Set documents1 = CATIA.Documents
Set drawingDocument1 = documents1.Add("Drawing")
drawingDocument1.Standard = catJIS           (开头)
  Set drawingSheets1 = drawingDocument1.Sheets
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
drawingSheet1.PaperSize = catPaperA0
drawingSheet1.Scale = 1.000000
drawingSheet1.Orientation = catPaperLandscape
Set drawingViews1 = drawingSheet1.Views
Set drawingView1 = drawingViews1.Add("AutomaticNaming")
drawingView1.x = 594.500000
drawingView1.y = 420.500000
drawingView1.Scale = 1.000000
Set drawingViewGenerativeLinks1 = drawingView1.GenerativeLinks
Set drawingViewGenerativeBehavior1 = drawingView1.GenerativeBehavior
Set partDocument1 = documents1.Item("Part1.CATPart")
Set part1 = partDocument1.Part
Set bodies1 = part1.Bodies
Set body1 = bodies1.Item("PartBody")
drawingViewGenerativeLinks1.AddLink body1
drawingViewGenerativeBehavior1.DefineFrontView 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000
Set drawingView2 = drawingViews1.Add("AutomaticNaming")
drawingView2.x = 696.064026
drawingView2.y = 318.935974
drawingView2.Scale = 1.000000
Set drawingViewGenerativeLinks2 = drawingView2.GenerativeLinks
Set drawingViewGenerativeBehavior2 = drawingView2.GenerativeBehavior
drawingViewGenerativeLinks2.AddLink body1
drawingViewGenerativeBehavior2.DefineIsometricView 0.390176, -0.920285, -0.028965, 0.458852, 0.167074, 0.872663
Set drawingView3 = drawingViews1.Add("AutomaticNaming")
drawingView3.x = 594.500000
drawingView3.y = 318.935974
drawingView3.Scale = 1.000000
Set drawingViewGenerativeLinks3 = drawingView3.GenerativeLinks
Set drawingViewGenerativeBehavior3 = drawingView3.GenerativeBehavior
drawingViewGenerativeLinks3.AddLink body1
drawingViewGenerativeBehavior3.DefineProjectionView drawingViewGenerativeBehavior1, catBottomView
Set drawingView4 = drawingViews1.Add("AutomaticNaming")
drawingView4.x = 696.064026
drawingView4.y = 420.500000
drawingView4.Scale = 1.000000
Set drawingViewGenerativeLinks4 = drawingView4.GenerativeLinks
Set drawingViewGenerativeBehavior4 = drawingView4.GenerativeBehavior
drawingViewGenerativeLinks4.AddLink body1
drawingViewGenerativeBehavior4.DefineProjectionView drawingViewGenerativeBehavior1, catRightView
drawingViewGenerativeBehavior1.Update
drawingViewGenerativeBehavior2.Update
drawingViewGenerativeBehavior3.Update
drawingViewGenerativeBehavior4.Update
drawingView1.Activate               (第一循环结束
Set drawingSheet2 = drawingSheets1.Add("AutomaticNaming")
Set drawingViews2 = drawingSheet2.Views
Set drawingView5 = drawingViews2.Add("AutomaticNaming")
drawingView5.x = 594.500000
drawingView5.y = 420.500000
drawingView5.Scale = 1.000000
Set drawingViewGenerativeLinks5 = drawingView5.GenerativeLinks
Set drawingViewGenerativeBehavior5 = drawingView5.GenerativeBehavior
Set body2 = bodies1.Item("Body.2")
drawingViewGenerativeLinks5.AddLink body2
drawingViewGenerativeBehavior5.DefineFrontView 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000
Set drawingView6 = drawingViews2.Add("AutomaticNaming")
drawingView6.x = 699.395508
drawingView6.y = 315.604645
drawingView6.Scale = 1.000000
Set drawingViewGenerativeLinks6 = drawingView6.GenerativeLinks
Set drawingViewGenerativeBehavior6 = drawingView6.GenerativeBehavior
drawingViewGenerativeLinks6.AddLink body2
drawingViewGenerativeBehavior6.DefineIsometricView 0.390176, -0.920285, -0.028965, 0.458852, 0.167074, 0.872663
Set drawingView7 = drawingViews2.Add("AutomaticNaming")
drawingView7.x = 594.500000
drawingView7.y = 315.604645
drawingView7.Scale = 1.000000
Set drawingViewGenerativeLinks7 = drawingView7.GenerativeLinks
Set drawingViewGenerativeBehavior7 = drawingView7.GenerativeBehavior
drawingViewGenerativeLinks7.AddLink body2
drawingViewGenerativeBehavior7.DefineProjectionView drawingViewGenerativeBehavior5, catBottomView
Set drawingView8 = drawingViews2.Add("AutomaticNaming")
drawingView8.x = 699.395508
drawingView8.y = 420.500000
drawingView8.Scale = 1.000000
Set drawingViewGenerativeLinks8 = drawingView8.GenerativeLinks
Set drawingViewGenerativeBehavior8 = drawingView8.GenerativeBehavior
drawingViewGenerativeLinks8.AddLink body2
drawingViewGenerativeBehavior8.DefineProjectionView drawingViewGenerativeBehavior5, catRightView
drawingViewGenerativeBehavior5.Update
drawingViewGenerativeBehavior6.Update
drawingViewGenerativeBehavior7.Update
drawingViewGenerativeBehavior8.Update
drawingView5.Activate         (第二循环结束)
发表于 2014-12-10 08:06:42 | 只看该作者
自己顶一下
发表于 2014-12-14 14:01:26 | 只看该作者
出大神
GMT+8, 2025-4-12 03:55 , Processed in 0.023234 second(s), 13 queries , Gzip On, Redis On.
