查看: 10103|回复: 0
[求助] 如何用CAA实现多组点云同时输入且各组点云分别存储?
发表于 2015-5-20 21:14:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题,下面是我的代码,iCount是txt文件的个数
                for(int i=0; i<iCount; i++)
                       CATIPrtContainer* pPrtCon = NULL;
                       rc= piNewContainer->QueryInterface( IID_CATIPrtContainer,(void **)&pPrtCon);
                       if (FAILED(rc) || pPrtCon == NULL)        return ;
                      CATIPrtPart_var spPart=pPrtCon->GetPart();
                       if(spPart==NULL_var)        return ;
                      CATIMechanicalRootFactory *pSetToolFactory=NULL;
                       rc=pPrtCon->QueryInterface(IID_CATIMechanicalRootFactory,(void **)& pSetToolFactory);
                       if(FAILED(rc)|| pSetToolFactory ==NULL)        return;
                       CATISpecObject_var spPRTTool;
                       spPRTTool= pSetToolFactory->CreatePRTTool("cloud",spPart);
                        for(int j=0; j<cloudpts[i].size(); j++)
                                CATIGSMFactory_var        spGSMFactory;                //GSM工厂,创建特征
                                spGSMFactory = NULL_var;
                                spGSMFactory = spPart;
                                CATMathPoint _Point;
                                float x,y,z;
                                x=cloudpts[i][j].x; y=cloudpts[i][j].y; z=cloudpts[i][j].z;
                                _Point.SetCoord(x,y,z);
                                CATIGSMPoint_var spPoint1 = spGSMFactory->CreatePoint(_Point); //创建一个点
                                CATIGSMProceduralView_var spSndPntObj = spPoint1;
                                spSndPntObj->InsertInProceduralView();
                        CATISpecObject_var        spSpecObject;
                        spSpecObject = spGSMFactory;
                        CATTry  spSpecObject->Update();
         编译没错,但是运行总是出问题,哪位大神帮忙解答一下呗~
GMT+8, 2025-4-10 21:03 , Processed in 0.021542 second(s), 13 queries , Gzip On, Redis On.
