查看: 16438|回复: 1
急助:可熔融加工橡胶(MPR)
发表于 2004-3-2 13:48:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
老外的图纸(好像是汽车车窗用品)选用的材料是MPR 一系列的牌号 如:APA-ALCRYN 2060 有无大侠知道相关的物性 是否可以注塑加工 急呀!
发表于 2004-3-2 16:32:19 | 只看该作者
APA Alcryn?2060 NC Melt-Processible Rubber
  Printer friendly version
Subcategory: Elastomer, TPE; Polymer; Thermoplastic
Close Analogs: 20 Alcryn?TPEs are listed in MatWeb.
Data provided by the manufacturer.
Key Words: Chlorinated Olefin Interpolymer Alloy; Advanced Polymer Alloys; Thermoplastic Elastomer (TPE)
Material Notes:
Alcryn?is a true thermoplastic elastomer, based on a partially cross-linked, chlorinated olefin interpolymer alloy. It is designed for the manufacture of rubber parts with high productivity on thermoplastic processing equipment. 2000 series characteristics: high flow in general plastics processing; designed for injection molding; excellent for complex extrusions; not suitable for calendering; black grades have excellent weather resistance.
No vendors are listed for this material. Please click here if you are a supplier and would like information on how to add your listing to this material.
Physical Properties Metric English Comments
Density 1.12 g/cc 0.0405 lb/in?/font>  ASTM D471
Viscosity 350000 cP 350000 cP  at 300/s at 190癈; ASTM D3835
Mechanical Properties
Hardness, Shore A 59 59  ASTM D2240
Tensile Strength, Yield 7.9 MPa 1150 psi  ASTM D412
Elongation at Break 420 % 420 %  ASTM D412
Tensile Modulus 0.003 GPa 0.435 ksi  ASTM D412
Flexural Modulus 0.0023 GPa 0.334 ksi  In Torsion; ASTM D1043
Graves Tear Strength 28 kN/m 160 pli  (Die C); ASTM D624
Taber Abrasion, mg/1000 Cycles 5 5  CS-17 Wheel, 1000g load; ASTM D3389
Compression Set 13 % 13 %  22 hr at 24癈; ASTM D395
Compression Set, Elevated Temperature 62 % 62 %  22 hr at 100癈; ASTM D395
Thermal Properties
Brittleness Temperature -85 癈 -121 癋  ASTM D746
Clash-Berg Stiffness Temperature -42 癈 -43.6 癋  69 MPa; ASTM D1043
Processing Properties
Processing Temperature 177 癈 351 癋  ASTM D3835
GMT+8, 2025-4-30 03:51 , Processed in 0.023749 second(s), 12 queries , Gzip On, Redis On.
